Suggestion Needed - Welcomed
Old Dec 30, 2013 | 09:08 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default Suggestion Needed - Welcomed
I am going to undertake rebuilding these lights from a 1975 and wanted to seek input from my fellow Corvette Forum members before beginning. I have a rebuild kit complete from Bair's (thank you John) for this project but wanted input on what others have done, learned, and would avoid if they were doing this project again.
Appreciate your thoughts.
Best regards,
David Howard
AllC34Me
Old Dec 30, 2013 | 09:30 PM
Frank_Nesta's Avatar
Frank_Nesta
Hi David. Take pictures and notes through out the disassembly process. Keep parts from each headlight separate. When you take anything with adjustments count the thread turns and take notes. Put them back with count of threads. This saves a lot of adjustment when installed back in the car. Spray every thing with something like Liquid Wrench heavily wait a day and take it apart. Clean the parts, prime, paint and re-assemble. Enjoy your project.
Old Dec 30, 2013 | 09:40 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Thank you Frank, good advice. Counting the turns on the threads never occurred to me, great point.
David Howard
Old Dec 30, 2013 | 11:26 PM
Frank_Nesta
David Howard
Yes those adjustments are not easy once they headlight assembly's are installed.
Old Dec 31, 2013 | 12:26 PM
20mercury's Avatar
20mercury
Default One source....
good how to, but a little pricey.
http://www.ecklerscorvette.com/corve...1968-1982.html
Old Dec 31, 2013 | 12:30 PM
gcusmano74's Avatar
gcusmano74
Do only one side at a time, so you can compare the two and put it all back together correctly.
Old Dec 31, 2013 | 03:15 PM
Mooser's Avatar
Mooser
with pretty much all of the above.
There are some subtle differences between left and right, high and low beam (watch the "pots") which make them sort of go together but not quite right
Mine from last year, (ignore all NCRS violations)
http://forums.corvetteforum.com/c3-g...s-forward.html
M
Old Dec 31, 2013 | 04:14 PM
Alan 71's Avatar
Alan 71
Hi,
Mooser's post is a beaut', and has/shows the info well.
The headlight pots do need to end up in the right place.
Looking at the front of the car they are:
C B D A
Good Luck!
Regards,
Alan
To Suggestion Needed - Welcomed
