Help on finding a SHORT
Old Dec 30, 2013 | 09:23 PM
hubcap's Avatar
hubcap
Default Help on finding a SHORT
1969 Convertible sbc.
Have a bad short. Placed a light between the neg terminal and the neg cable. Disconnected each fuse individually and the alternator but still the light is on bright.
What would be the next logical step in finding the short please.
No fuses have blown.
No A/C. New Battery. New Alternator.
Any/All suggestions appreciated.
FYI have no access to car for next 2 weeks but would like to plan
ahead with this problem.
Thanks Mike
Old Dec 30, 2013 | 09:38 PM
Peterbuilt's Avatar
Peterbuilt
Default Bin working on the starter or wiper motor?
The black ground wire for the wiper motor and fan should be on a starter or bell housing bolt, could that wire be on the battery terminal on the solenoid by mistake?
Old Dec 30, 2013 | 09:41 PM
Frank_Nesta's Avatar
Frank_Nesta
Thanks Mike
Hey Mike, What is exhibiting the problem that make you think you have a short? Is it a slow drain on the battery?
Old Dec 30, 2013 | 09:43 PM
TimAT's Avatar
TimAT
First place to look. Make sure the key is off too. After that, think about the things that are powered all the time- like the headlight switch, horn, stop lights, and interior lights.
Old Dec 30, 2013 | 09:51 PM
Frank_Nesta
Check this link.
http://www.dsmtuners.com/forums/arti...ery-drain.html
micks69's Avatar
micks69
Old Dec 30, 2013 | 10:01 PM
Frank_Nesta
Originally Posted by micks69
Mick, but should we have a AIM comment? LOL
Old Dec 30, 2013 | 10:09 PM
hubcap's Avatar
hubcap
Frank, battery goes down within 2 days to approx. 10v after one week it is basically dead. Mike
Old Dec 30, 2013 | 10:20 PM
Frank_Nesta
You can use the link I posted above. I usually hook a multimeter up to the battery using the amp meter highest setting. Then remove and replace each fuse looking for a biggest change. That gets me to the correct circuit.
This is the process I use.
http://www.theimportkiller.com/forum...hp?topic=321.0.
In a corvette the doors need to be shut. So you need to have the door switch closed. The manual is not necessary. The fuses are all located in one spot.
Last edited by Frank_Nesta; Dec 30, 2013 at 10:36 PM. Reason: Corrected word and link
Old Dec 30, 2013 | 10:48 PM
hubcap's Avatar
hubcap
Thanks everyone, once I get the car back from the paint shop in a couple of weeks I'll follow all above and advise.
Thanks again Mike
Old Dec 31, 2013 | 12:16 AM
Peterbuilt's Avatar
Peterbuilt
Default Another wild guess!
You might want to check the anti theft circuit, if the horn does not work but the relay is "ON", that will drain the battery.
Old Dec 31, 2013 | 08:41 AM
micks69's Avatar
micks69
Frank I'll leave that to the "AIM experts"
To Help on finding a SHORT
