Installing a roller cam and Im setting the cam button. Ive heard all sorts of things about the stock timing cover being fine, Ive heard about welding a plate on the outside and Ive heard that only an aftermarket cover will work. I can tell you my stock timing cover is quite stout and I had to really pry to get it to move. Opinions?
On my sbc I JB welded a plate onto the front of the timing cover, then spaced the water pump with gasket thickness so that back plate on water pump just touches the plate on the timing cover. This seems to work well and keeps things from flexing. Initially the timing chain cover flexed and allow cam to walk. OEM timing chain cover on my 350 was thinner guage and flexed more than the aftermarket one I replaced it with.
I'm going to ask a real question. What if you install one of the highest quality double roller timing chains, with billet timing gears, with a Torrington type bearing between the block and timing gear? Then take the time to correctly position the lower gear on the crank to not load the Torrington bearing.
The double roller chain is extremely ridged against bending in the fore and aft direction.
Well after careful consideration, I put my stock cover back on. Ive read enough now and several people say a stock, OEM cover is fine. Lets hope for the best.
I'm going to ask a real question again. What if you install one of the highest quality double roller timing chains, with billet timing gears, with a Torrington type bearing between the block and timing gear? Then take the time to correctly position the lower gear on the crank to not load the Torrington bearing.
Just keep thinking about how far does the cam really move back and forth in the block when held by a stiff timing chain. Because the only forces applied in either the for or aft direction is the helical cut distributer gears driving the shaft and oil pump.
Does that oil pump load push the cam forward or pull it back into the block?
