LS motor mounts. Need info
Old Dec 31, 2013 | 07:42 AM
Gordonm's Avatar
Gordonm
Default LS motor mounts. Need info
Guys, I was at AR headers yesterday and we were talking motor mounts. Now they are using Dirty Dingo slider mounts. I have a set of Dirty Dingo mounts but from all my info and measuring it puts the motor in the stock location. They are using the slider mounts but Phil their fabricator who also owns a C3 and fit the headers using his 78 puts the sliders in the stock location also. Here is a picture of where my mounts sit. The lower hole in the 3 bolt stock mounts goes into the front hole on the LS block. This seems to put the motor in the stock location. I tried mine moving the motor back and then forward and the stock location seemed to be the best fit for everything. It would give the stock AC guys room for the box and it keep the pulleys in a good location. I relayed this info onto AR but just want to confirm that most guys are putting it close to the stock position. They have to make a header fit everything, and not make custom ones for everybody. Let me know your thoughts on this. We will get these out there and I may have to just get my car up to them.
Old Dec 31, 2013 | 09:07 AM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
DD slider mounts here as well, although my motor is not in the car yet....
The plan was to keep it as close to the stock location as possible.
Old Dec 31, 2013 | 01:56 PM
ignatz's Avatar
ignatz
VetteAid mounting plates AND z-bracket
http://vettaid.com/LSxPackagesKits.aspx
Energy Suspension motor mounts - I see they also make an adapter kit
http://www.energysuspensionparts.com...sp?prod=3.1148
Everything in stock location, except the motor sits a little high!
Old Dec 31, 2013 | 02:35 PM
Garys 68's Avatar
Garys 68
When I was measuring things up, it looked like the plates that share that bottom bolt hole would result in the motor/trans face would be forward of the original location. The setback plates in the VetteAid post pic moved it about 1/4" from original location.
Old Dec 31, 2013 | 02:49 PM
74modified's Avatar
74modified
I know this wont help your cause, but throwing it out for anyone using this thread to pick their mounts.
I made stock location plates and didn't like them. I ended up changing them to lower and move the engine a hair rearward. This way worked better with the transmission I was using - using C5 manifolds anyway.
Old Dec 31, 2013 | 03:13 PM
ignatz's Avatar
ignatz
The original Muncie transmission dropped into the original holes with no modification. Same with the linkage, nothing changed. Z-bar went where it was supposed to. If there's a 1/4" difference it seems to have been accommodated somehow.
My only gripe is the height, it would be nice if someone could integrate the mount with the adapter plate so that the motor didn't sit as high. But that is a different thread.
Old Dec 31, 2013 | 03:33 PM
1978LScorvette's Avatar
1978LScorvette
Hey Gordon its Pat, as we had talked about the motor placement I found the hooker headers part number 12623 HKR and it says it puts the motor 1 1/4 forward with the same bolt hole in the bottom mount to boss on the block. I looked at mine again(home made) and im using the same bolt hole as u and hooker. What type of dirty dingo plates are u using?
Old Dec 31, 2013 | 03:36 PM
Garys 68's Avatar
Garys 68
I would be surprised if anything on my 45 year old car was within 1/4" specs.
Old Dec 31, 2013 | 04:35 PM
Gordonm's Avatar
Gordonm
Cant remember which ones they were but I have to do a little more research as to what ones I am using. These are about 2 years old now. AR is using sliders but in talking with Phil who owns the C3 and is the header fabricator he seemed to think it was very close to the setup I am running. I. Think most are running this way.
Old Dec 31, 2013 | 06:58 PM
1978LScorvette
Yeah I had said to him that I had believed we have similar applications but when I spoke to Phil ,I was asking him as to where the location of the bottom motor mount bolt was in proportion to the front bottom boss on the block.He could not tell me at the time but was pushing the adjustability of the sliders. Correct me if Im wrong but it really doesnt matter what type, what brand or even home made if the bottom bolt is in the same position(through the mount, the mounting plate and into the front bottom boss). the location of the block will b the same which I had stated before that according to hooker it places the motor 1 1/4 forward. I have no knowledge of an offset motor mount so I think it should b typical throughout. So maybe the question should be where the the location of the bottom bolt in relation to the bottom front boss is? Im going to b in the garage 2morrow and take some pics so u can see my application. good thinkin for the post!
Old Jan 1, 2014 | 11:57 AM
Gordonm's Avatar
Gordonm
I was going off the measurement of the back of the heads to the firewall. The LS heads are approx in the same location as the Gen1 heads. So it may move the LS motor ahead but the physical spot the motor sits is in approx the same location as the Gen1 motor.
Yes if the lower bolt is in the same hole regardless of brand of motor mount the motor will be in the same location.
Old Jan 1, 2014 | 01:03 PM
1978LScorvette
ok,Ihad the body pulled and the engine is gone so I couldnt compare. Is ARH going to give you the headers back to try out with the adjustments that you gave them? If so maybe you could stop on the way back home and I could try them. I would of asked you before on your first trip but we didnt talk till you had already dropped them off. pat
Old Jan 1, 2014 | 05:15 PM
Gordonm's Avatar
Gordonm
We are working on some solutions. They want my car there but with the weather that is coming and it is a hassle to get my car there I'm not sure if I will get it there any time soon without a great incentive. You are welcome to trial fit them once I get another set in my hands for sure.
Old Jan 1, 2014 | 10:16 PM
CWerner's Avatar
CWerner
I'm using CIC mounts. Josh told me they position the engine in the original location.
Old Jan 2, 2014 | 01:03 PM
ignatz's Avatar
ignatz
Am I the only person that wants the z-bar to fit?
Old Jan 2, 2014 | 06:48 PM
Garys 68's Avatar
Garys 68
I used the Z bar with my LS I initially had the 1" setback plates and it was close to stock. But the 621 bell combined with slightly raised engine, Richmond trans, and sagging body resulted in the bell contacting the tunnel. Add to that, the trans yoke was very close to bottoming out...I went for the shared lower bolt hole plates.
I just redrilled the Z bar mounts on both engine and frame to square it. Z bar clears the C5 exhaust, O2 sensor.
Btw, ended up using the 1" setbacks for my Olds swap with stock Z bar.
Old Jan 2, 2014 | 07:06 PM
74modified's Avatar
74modified
One of the main reasons for my swap was to also have a modern 6 speed. No Z bar needed, and I couldn't use the trans cross-member in stock form - - so I moved everything to get the best fit.
To LS motor mounts. Need info
