small starter - 1976
Old Dec 31, 2013 | 09:35 PM
fspalti@netscape.net's Avatar
8th Gear
Default small starter - 1976
I purchased a small starter when the original one started having problems after the car ran for a while. I installed the new one as it was sent from Summit. It did not engage the flywheel. I moved the starter to an alternate mounting point. It still did not engage the flywheel. There are some adjustments that seem to want to rotate the starter. Any suggestions on what I need to do?
Old Dec 31, 2013 | 11:06 PM
TOM B1's Avatar
TOM B1
Wrong starter, auto or manual.
Old Jan 1, 2014 | 03:12 AM
8th Gear
Default starter - 1976
auto
8th Gear
auto
Old Jan 1, 2014 | 11:49 AM
Ironcross's Avatar
Ironcross
auto or stick, same starter......if its the small GM starter replacing the large case starter it should fit......If its one of those imports with an adapter cant help......the small gear reduction GM is the way to go however.....
To small starter - 1976
