A question for Big Block owners
Old Jul 10, 2002 | 09:41 PM
Corey_68's Avatar
Corey_68
Default A question for Big Block owners
How do I run tall valve covers with my power brakes? Do I have to get a smaller booster or relocate it? :confused:
Can anyone help me out?
Old Jul 10, 2002 | 10:02 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: A question for Big Block owners (Corey 68)
I had problems with mine also, I went through three different sets of valve covers before I found some that fit. I went with the Chevy Bow Tie racing valve covers but at $300.00 per set they hurt. I have some of the chrome Moroso valve covers that will also fit if you are interested. You selection will be limited.
Old Jul 10, 2002 | 10:08 PM
Corey_68's Avatar
Corey_68
Default Re: A question for Big Block owners (69 N.O.X. RATT)
I have a couple sets of tall covers here. Do you have any measurements on the heigth so I can compare them to mine?
:cheers:
[Modified by Corey 68, 8:52 PM 7/10/2002]
Old Jul 10, 2002 | 10:48 PM
oger's Avatar
oger
I took an old set of MTs that cleared the roller rockers and cut the corner out and welded a plate across it. It cleared the rollers and the power brake unit on my 66 BB car.
Old Jul 11, 2002 | 12:35 AM
73 LS-4's Avatar
73 LS-4
I got a set of tall Billet Specialties to fit, but it took a little work and bending and grinding, especially by the brake booster, if you have A/C then you'll have to clearance that side some as well. It took some work but they gave me plenty of clearance for my roller rockers. I could measure the height of mine if you want, but a little shorter then mine would be a lot less work, trust me :yesnod:
:cheers:
Pat Kunz
Old Jul 11, 2002 | 01:40 AM
Chuck Harmon's Avatar
Chuck Harmon
I have full roller rockers and these covers clear my power brake booster with no problems whatsoever.
Chuck
Old Jul 11, 2002 | 02:26 PM
GDaina's Avatar
GDaina
using stock covers w/full roller rockers, but don't have power brakes
Old Jul 11, 2002 | 03:13 PM
groovyjay's Avatar
groovyjay
Default Re: A question for Big Block owners (GDaina)
I'm getting hydrabooster from Norval this is the cure when running very tall valve covers ( I have to I'm running stud girdles). :cheers:
Old Jul 11, 2002 | 03:40 PM
Wrencher's Avatar
Wrencher
Default Re: A question for Big Block owners (groovyjay)
Hydroboost is the way to go, especially if you have power steering.
Hans
Old Jul 11, 2002 | 07:18 PM
Corey_68's Avatar
Corey_68
Default Re: A question for Big Block owners (Wrencher)
Hans
Where do I get this?
Old Jul 12, 2002 | 09:41 AM
mountainmotor's Avatar
mountainmotor
Norval got me fixed up on the Hydro Boost system. Do a search on it or possibly Norval will chime in with a link to one of his prior posts.
A great brake system IMO !
Old Jul 12, 2002 | 10:13 AM
Twin_Turbo's Avatar
Twin_Turbo
Look in the boneyard for 70's chevy trucks, the diesel ones had them and some later model gas powerde also. If you grab one, get the lines too, that'll save you a lot of grief getting the correct fittings etc.
Marck
Old Jul 12, 2002 | 01:15 PM
bb69's Avatar
bb69
Default Re: A question for Big Block owners (mountainmotor)
I bought a pair of chrome covers on eBAY for about $50 bucks. I then persuaded the cover out of the way using a 2.5 inch socket and mallet. It didn't bother the chrome at all, and when it's put together, it's very hard to see. The key, is screwing the cover down when massaging it. I know this isn't the best way, but by the time the rebuild was done, I had hemoraged enough cash, and new covers will have to wait.
Old Jul 12, 2002 | 02:16 PM
MassVette's Avatar
MassVette
Check this site out:
http://www.hydroboost.com
Old Jul 12, 2002 | 09:49 PM
shawn_cake's Avatar
shawn_cake
Custom fabricated my tall valve covers on my big block - roller rockers and stud girdles. See pics on link in my sig..
:D :seeya
[Modified by shawn_cake, 6:49 PM 7/12/2002]
Old Jul 13, 2002 | 12:50 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: A question for Big Block owners (oger)
Mine has also welded corners,both a..Very tall Erson covers..One cover almost hits the Powerbrake servo and the other one almost hits the heatercore assembly(AC)... :cheers:
Old Jul 13, 2002 | 12:55 PM
bence13_33's Avatar
bence13_33
Corey:
I'm currently running Mickey Thompson valve covers that will work with full roller rocker arms. I did not have to do anything to them but bolt them on. It's somewhat close to the brake booster but I can still install/remove them very easily.
To A question for Big Block owners
