79 L-82 heads
or thought on double hump heads period.
thanks
cylinder and test compression again. If it jumps up it is rings. A leakdown test is also useful.
Before you even get into what sort of heads you want, you need to make sure the bottom end is worth putting new heads on.
If it is, then I'd say you are wasting your time and money with old cast iron heads. The "double hump" heads seem to have this reputation for being really awesome heads, and I guess they probably were.....40 years ago. Nowadays, you can get aftermarket aluminum heads that kick the crap out an old set of "double humps" for less than a grand.
If the bottom end is not worth putting new heads on, then you have some work to do, which will involve either a machine shop, or a crate motor, both of which will be relatively pricey, compared to a 75 dollar set of heads.
I'll also agree that if the heads are in good shape, it's worth doing. Again, if the bottom end is in good shape. But, I doubt you will find freshened up "double humps" for 75 bucks, people seem to think they are made of gold, or something.
Edit: Apparently, the double hump heads have no provision for bolting accessories on the front of the engine, which kinda throws a wrench into the clockwork, so even if they are in good shape, it doesn't sound like a good idea.
Scott
JMO
Bill A.
http://forums.corvetteforum.com/c3-t...flow-data.html
