1969 head advice
Old Jan 10, 2014 | 10:58 PM
CanadaGrant's Avatar
CanadaGrant
Default 1969 head advice
Below is a pic of the original 69 427 setup. The bolt that looks like it is loose directly above the water pump pulley and to the right of the AIR pump is actually broken. The other end is stuck in the head. The motor has never been out of the car since factory and I noticed this while doing a rad repair and replacement.
What now? It is broken off even with the face of the head.
Another pic:
Old Jan 11, 2014 | 08:47 AM
garygnu's Avatar
garygnu
spray it with some good lube like jb80 .center punch it in the middle .drill it with a small drill bit to start .drill it out enough to use a easy out bit .or use a left handle tap and bolt to remove it .
Old Jan 11, 2014 | 10:32 AM
76strokervette's Avatar
76strokervette
Drilling it with left hand drill bit may walk it also if the fastener was not bottomed out.
Old Jan 11, 2014 | 12:17 PM
restoman1's Avatar
restoman1
Your problem isn't an isolated instance. A lot of bolts broke in that location due to the Z-bar brace putting excess stress on the bolt. In late 1969, GM went to a little bit different arrangement to cure this problem. You can read more about it HERE, and make sure you get the late 1969-1974 brace when you get it all straightened out.
Ed
Old Jan 11, 2014 | 01:31 PM
RobRace10's Avatar
RobRace10
You can also take a nut, place it over the bolt hole then weld through the center of the nut, thus welding the old bolt to the nut. The heat will loosen the bolt and then just put a wrench to the nut and it will spin out.
Old Jan 11, 2014 | 02:22 PM
CanadaGrant
Thanks. I am going to give this one a shot. I do not want to pull the head off an original old motor and play around. Your idea sounds good. I tried an easy out this morning but it is either bottomed out or cross threaded in the block.
Old Jan 11, 2014 | 02:31 PM
briankeery's Avatar
briankeery
MIG will have that out in 10 minutes. Good luck.
Old Jan 11, 2014 | 03:10 PM
garygnu's Avatar
garygnu
I recommended using a left handed tap ,not a left handed drill bit .wear some good welding gloves if you weld a nut on to it .that is the easier and faster way to remove it .
Old Jan 11, 2014 | 04:01 PM
restoman1's Avatar
restoman1
I haven't used them, but I saw THESE in an infomercial yesterday. Might be worth giving them a shot.
Ed
Old Jan 11, 2014 | 04:37 PM
Gale Banks 80''s Avatar
Gale Banks 80'
One of the reasons the welded on nut works so well is because the heat breaks everything loose. Then when the hot remaining portion of the bolt cools down it shrinks and will end up a smaller diameter than what it started out. If You don't have a way to weld it You can get both of these advantages buy just heating it and letting it cool. If You have already drilled a hole its that much better. Preferably You would use a acetylene torch and shoot the heat right down the hole, or just try what ever you have. You might be surprised at how much it shrinks when it cools. It might just about fall out.
Old Jan 11, 2014 | 09:09 PM
CanadaGrant
Ed
Thanks Ed. That makes sense. The motor has never been out of the car and it still runs great after 45 years. I tried an easy out but was afraid it might break off so am going to weld a stud on. If I break an easy out in the head it's game over as it won't drill out. I have the rad and support out so have a straight shot at it. Fine line here between easy and a whole bunch of trouble.
Old Jan 11, 2014 | 09:28 PM
CanadaGrant
Thanks Gale. I'm going to weld a stud on through an outside "jacket". If it doesn't work I can still drill it out without ruining the head. My wife thinks I should just take it apart and fix it but it's a really nice original old car and I would like to leave it close to the way I found it.
Old Jan 11, 2014 | 10:31 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Take a Dremmel and cut a slot in the bolt.....
Heat with a MAPP torch and back it out with a screwdriver....
That is a bad place to try and drill and the weld/nut option may not work as the bolt is broke off recessed....
Jebby
Old Jan 11, 2014 | 11:09 PM
CanadaGrant
Jebby
Thanks Jeb. My plan is to take a piece of 1/4 inch pipe and cut a slot in it. Slide it in the bolt hole and weld it through the slot to the bolt with a mig. Cover the inside with material then try and back the bolt out while it's still hot. If it doesn't work I can still drill it but don't want to screw up this head.
Old Jan 11, 2014 | 11:44 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Good luck to you.....
I assume the reason you are there is to do some detailing?
I have a 427 myself and although it is a clean "patina" survivor...I will be detailing it in the near future......
Do you have a pic of your car?
Jebby
Old Jan 12, 2014 | 12:09 AM
CanadaGrant
Jebby
Sure,
My car is an original old 427. It has not been touched and still has the original AIR pump and still looks like it just came from the factory. The most important part is that my wife found it sitting on the side of the road and bought it. It's hers. The guy that owned it died and his wife actually put it out on the side of the road with a "for sale" sign in the window.....
The last pic is from her cellphone when she found it. Her first question that came with the pic was:
"You got an extra 30 grand because I just spent it and don't feel bad because they were asking forty". It was just sitting on the side of the road. Really nice old car. The seat foam was rotten so I ended up doing a complete interior. Even the original clock works. I have a few other Corvettes but this is by far the best thing I could ever hope for and my wife still thinks it's hers....
Can you imagine sitting at home and you get a text with that pic? I rented a trailer and met my wife in Vancouver and had more thumbs up on the way home that I can even remember. It costs her about six bucks each way just to drive to the grocery store which is less than 3 miles away but the smile is worth it. Really worth it.
Old Jan 12, 2014 | 12:13 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Sure,
Wow! Great find...love the yellow....
This is mine.....
Have fun with that...I have had mine a month and love it...traded a 66' 327/300 for it....
Jebby
To 1969 head advice
Old Jan 12, 2014 | 12:49 AM
CanadaGrant
This is mine.....
Jebby
Aw man.... You just can't get any better than that. Really nice. I would trade a kidney for that puppy and still come out with a smile.
Old Jan 12, 2014 | 01:09 AM
1wicked55's Avatar
1wicked55
Change your heads from side to side. The broken bolt will be on back that way
Old Jan 12, 2014 | 01:22 AM
CanadaGrant
I thought of that but don't want to open a can of worms. It's an old car that I am just trying to leave alone and don't want to pull the heads for a bolt.
