Testing Tach
Old Jan 14, 2014 | 09:21 AM
Dave Witman's Avatar
Dave Witman
Default Testing Tach
Does any one know if the tach signal generator that willcox sells will test a tach that is installed in the vette. Also would it test aftermarket tachs for accuracy. Dave
Old Jan 14, 2014 | 10:44 AM
zwede's Avatar
zwede
Answers are in the product text at the willcox site????
This signal generator will allow you to either bench or car test your tachometer.
Test your tachometer on any GM car from 1975-1991 that uses a distributor signal for operation.
Old Jan 14, 2014 | 10:56 AM
Dave Witman
Thankyou I must have not read it all.
Old Jan 14, 2014 | 11:02 AM
mrvette's Avatar
mrvette
Being an old ET, I have a slight advantage in that I took a digital audio oscillator, and Tektronics scope to my HEI, too that tach wire to a power transistor, drive the transistor with the oscillator, and monitor with the scope, I found the tach was accurate at idle, and at 2500 rpm, but when at 3000 rpm it was optimistic by 10% signal was really 2700 or close.....at 4500 indicated, it was only 4000 in reality....
by 6000 rpm it was optimistic by some 650 rpm....10% off....
so yes, factory tachs are not accurate, same as the speedometers....
Old Jan 14, 2014 | 12:28 PM
zwede's Avatar
zwede
I'm also particular about accurate gauges. I have the willcox tach board and it has a calibration pot on it (factory board is non adjustable). I built a signal generator and monitored the output on my scopemeter (remember that one, Gene?).
I was able to get an accurate sweep all across the scale by needle position & trim pot adjustments.
For the speedo, I compared it to the reading on my GPS. I found it to be 8% high, so I adjusted it to where now it reads 1-2 mph high.
To Testing Tach
