Cylinder head storage
Old Jan 18, 2014 | 12:37 PM
haydenray's Avatar
haydenray
Default Cylinder head storage
After contacting several crate motor builders and finding the "affordable" engines all use recycled cranks and rods, I am having my original '74 L48 rebuilt with new stronger bottom end parts a retrofit hydraulic roller cam with new Dart heads. Leaving the matching VIN code on the block.
I don't know if a future owner might want to restore the engine to original, but just in case I want to store the cam, heads and valve covers for posterity. I am thinking I should find some type of spray grease and plastic wrap to prevent rut. Any tips? Interested in what has worked for others in the past.
Thanks,
Ray
Old Jan 18, 2014 | 01:24 PM
1977L48's Avatar
1977L48
that would work, i was storing a set of 400 heads in a box inside my house, so humidity wasent a factor, i found out the hard way after storing a set of 781 heads in my shop on cardboard, they rusted rather badly after about a year. just my .02
Old Jan 18, 2014 | 01:29 PM
Solid LT1's Avatar
Solid LT1
I like motorcycle chain lube and plastic bags taped up with duct tape, the bags are redily avalible at an auto machine shop. I have a pair of Bob Johneck 292 Turbo heads stored this way. The holy grail of 1970's Chevy heads for a SBC
Old Jan 18, 2014 | 02:18 PM
billla's Avatar
billla
St. Jude Donor '14
I've successfully stored heads for decades spraying with WD-40 and bagging them.
Now...this usually brings folks out of the woodwork, because WD-40 does indeed turn "gummy" after a while. IMHO, that's fine - anything stored that long is going to need to be disassembled and hot-tanked anyway. Just about any lube is going to do that over time, even a light spray of oil. But it's worked for me, 100%, every time. Just one guy's take.
Old Jan 18, 2014 | 04:12 PM
BOOT77's Avatar
BOOT77
I know a friend who used fogging oil on some heads in ihs basement wrapped up in plastic.
Old Jan 18, 2014 | 07:32 PM
haydenray's Avatar
haydenray
Thanks for the tips. I should have kept the bags from the new heads. Just had a call that the engine is finished. I'll see if I can grab some at the shop.
Should have the new one in in a week,but it's too icy here to give it much of a try.
Ray
Old Jan 18, 2014 | 07:46 PM
7t9l82's Avatar
7t9l82
put the cam in a section of 2" P.V.C pipe with 2 caps just taped on, spray with some oil first. spray the heads etc and bag them up, if you can keep them from getting bumped around a desiccant to remove moisture will help, i used freeze dried coffee one time and it worked o.k and had a nice smell haha.
To Cylinder head storage
