pro comp heads
Old Jan 19, 2014 | 01:29 PM
bballboy06's Avatar
bballboy06
Default pro comp heads
i am looking at aftermarket heads and have read mixed reviews on these
can anyone give me their thoughts on pro-comp heads.
the would be going on a 79 l-82, with dual exhaust magnaflow
thanks
Old Jan 19, 2014 | 02:56 PM
Conrad Celinski's Avatar
Conrad Celinski
Also interested in any info on these, and work that they need
Old Jan 19, 2014 | 03:38 PM
sweeet76's Avatar
sweeet76
I don't know anything about the Pro-Comp heads but Hot Rod magazine did a test on all heads selling for under 1,000.00. I think the article was in Sept 2011 or 2012. You can probably google the article.
Good Luck,
Bill
Old Jan 19, 2014 | 05:06 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Good Luck,
Bill
Not Hot Rod, pretty good article, though. Doesn't seem to be a huge difference.
http://www.carcraft.com/techarticles...head_shootout/
I'm leaning towards the Patriot's which apparently are the same as ProMaxx sold by Summit.
Old Jan 19, 2014 | 06:37 PM
sweeet76's Avatar
sweeet76
Capt. Shark, thanks for the help. Seems like my memory goes down hill a little more each year. I actually have a set of patriot heads on my 76 and have no problem with them. I guess if I were going to the drag strip or really abusing my car, I might have gone with something different, but for around town and on an open highway, with my 4 speed, they work great for me. I also know 1977L48 has a set he is happy with.
Good Luck,
Bill
Old Jan 19, 2014 | 07:04 PM
7t9l82's Avatar
7t9l82
i have the 190 runner 64 cc chamber ones on my L-82. i would recommend buying them bare and have a competent person assemble them .( as i did ) the castings are fine but the components are cheap. i did a good bit of port and bowl work on mine and they work very well. a really nice bost in performance. if you have the L-82 cam the 1.6 rockers will help you utilize the extra flow.
Old Jan 19, 2014 | 09:47 PM
Capt. Shark
If I were going to build a firebreather, I would seriously consider AFR heads. For what I'm looking to do, though, I just can't see double the money for the AFRs over the Patriots (ProMaxx). Specially as I'm just planning on keeping my L82 intake and cam.
If I'm wrong, I am certainly willing to hear why.
Old Jan 19, 2014 | 10:22 PM
Indiancreek's Avatar
Indiancreek
Like anything else, you get what you pay for most of the time.
Old Jan 19, 2014 | 10:25 PM
7t9l82's Avatar
7t9l82
there isn't a right or wrong, it is what you feel is best for you. i still recommend buying the heads bare and having a competent person assemble them.
Old Jan 19, 2014 | 10:28 PM
bluedawg's Avatar
bluedawg
Chris Straub at straub technologies sells the patriot heads for around $700.00 a pair. Good dude to do business with. I'm an afr fan, but for budget heads they flow 250 @ .500" if I recall.
Old Jan 19, 2014 | 10:36 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Better option than the Pro Comps.
Old Jan 19, 2014 | 10:50 PM
bluedawg's Avatar
bluedawg
My thoughts exactly. Ain't afr but not bad for a budget head, $700 for an resembled set of aluminum heads were Chris will match the springs to your cam.
Old Jan 21, 2014 | 07:54 AM
bballboy06's Avatar
bballboy06
Angleplug,64cc chamber,screw-in studs&guide plates. 1.5 and 1.6 roller rockers, push rods
there are the specs for the, they came off of a 383 that was running 5.9 1/8ths.....they cost me 500 with everything
good deal?
Old Jan 21, 2014 | 08:07 AM
7t9l82's Avatar
7t9l82
what heads? are the springs o.k for the application. has anyone been through them ? might be a very good deal. if you have the L-82 cam i would use the 1.6 rockers all around, but both are fine.
Old Jan 21, 2014 | 09:18 AM
StraubTech's Avatar
StraubTech
The Patriot head was/is a good little casting from offshore. It is capable of making 500HP base on the flow numbers out of the box.
AFR, very good head. Makes very good power.
Old Jan 21, 2014 | 09:24 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
$700 a pair?
Did I hear you correctly?!
That's a great price for heads that actually perform!
Old Jan 21, 2014 | 11:28 AM
bluedawg's Avatar
bluedawg
Originally Posted by doorgunner
$700 a pair?
Pm the owner of the post above you or go to straub technologies web site. For a budget type build they sound idea with flow numbers at 250 cfm @ .5" on a 195cc runner for the money, the out flow the edelbrock rpms that I had on my l48. I've not seen them personally, but my dealings with Chris have been good and hes got a good rep on several forums. I'm an afr fan but for dome one not looking to spend $1500....
To pro comp heads
Old Jan 21, 2014 | 11:34 AM
bluedawg's Avatar
bluedawg
good deal?
What make of head? Flow numbers? What size of runner? Springs will need to match the intended cam.
Old Jan 21, 2014 | 12:14 PM
bballboy06's Avatar
bballboy06
these are pro comp heads....
Combustion Chamber
64cc
Intake Runner Volume
190cc
Exhaust Runner Volume
80cc
Intake Port size
1.175W x 2.020H
Exhaust Port size
1.420W x 1.350H
Spark Plug Style
Angle or Straight
Intake Valve Diameter
2.020 in.
Exhaust Valve Diameter
1.600 in.
Rocker Stud Thread Size
7/16 - 20 in.
Accessory Bolt Holes
Yes
Valve Guide Material
Bronze
Valve Seats Machined
Yes
Valve Seat Style
Multi Angle
Valve Seat Material
Hardened Ductile Iron
Intake Bolt Pattern
Early Chevy or late (Vortec)
Valve Cover Mounting
Center and perimeter bolt
Old Jan 21, 2014 | 01:29 PM
bluedawg's Avatar
bluedawg
Combustion Chamber
64cc
190cc
80cc
Intake Port size
1.175W x 2.020H
Exhaust Port size
1.420W x 1.350H
Spark Plug Style
Angle or Straight
2.020 in.
1.600 in.
7/16 - 20 in.
Yes
Bronze
Yes
Valve Seat Style
Multi Angle
Valve Seat Material
Intake Bolt Pattern
I can't say there bad as I can't say there good. There's members that bought them and spent money having cleaned up and ported and are pleased with them, but I've not nor would I use them. I'd bet a nickel to a dollar that the ones that ''ran a 5.91" were not out of the box heads. I'd Call Chris and ask about his heads at only $200 more being on a tite budget. but that's me. good luck.
