pro comp heads
Old Jan 21, 2014 | 03:29 PM
7t9l82's Avatar
7t9l82
i have heard the newer patriots are made in the same foundry as the pro- comps. i will say it again , i would never take a set of anyones heads out of a box and bolt them on. i don't care if it is dart afr or anyone else's. and i don't buy assembled heads unless i know who put them together AND have faith in their work. the first time you have a retainer or valve let go at 8k rpms at over 130 m.p.h let go you WILL know why. even the same thing happening at 3k rpms on the street you will understand why you check. it can and does happen no mater how much or how little you spend. nothing will destroy an engine quicker. but then, what does a guy running pro- comps know
Old Jan 21, 2014 | 04:53 PM
StraubTech's Avatar
StraubTech
What you have heard is 100% wrong on the Patriot/Pro Comp connection. Patriot was a division of ACHC. They were and still are one of the large suppliers in aftermarket casting to the production engine rebuilders. Their castings had to meet or exceed OEM specificiations including some applications used by the Military. They do heads and do them well. Companies that do everything usually don't do anything real well.
Old Jan 21, 2014 | 05:56 PM
bluedawg's Avatar
bluedawg
A little sensitive? You are my example of members running procomps after spending additional money on them and are pleased. There your heads, you like them and they work for you. Ain't that all that really matters?
Old Jan 21, 2014 | 07:41 PM
7t9l82's Avatar
7t9l82
i appreciate that bluedawg.
aparently i was informed incorrectly on the foundry information.
but i stand on my other comments.
Old Jan 21, 2014 | 07:55 PM
bluedawg's Avatar
bluedawg
That's ok.
Old Jan 30, 2014 | 02:25 PM
c3_dk's Avatar
c3_dk
I bought Pro Comps 190 heads bare, and have them made so they fit my engine. I've ordered 2.05 valves, instead of 2.02
Does anyone know what heat range of spark plug I must buy?
Here is my heads, the same guy also have my intake and headers. He is grinding/cutting from the throttle body to the exhaust.
Old Jan 30, 2014 | 04:29 PM
boat196's Avatar
boat196
ProComp 190cc Stage IV "Denmark Duo" Chambers 4.5 Final Rough Cut - YouTube
How long did it t take to have a bare set of heads ported and assembled.
Bob
Old Jan 30, 2014 | 04:56 PM
Aumie's Avatar
Aumie
My Skip White NKB heads just shipped today so I can't vouch for them yet, they are 2.02, 1.6; 64 cc; with 200 cc intake runners and I got them for 645$. Really the only reason I went with them over the others was the 3 yr warranty, which I hadn't seen with the other "cheap" heads. (What was that Tommy Boy's dad said about guarantees?) Couldn't justify the 1K+ for heads on my budget. Some people have large amounts of dispensable income and some don't. I don't so I try to save a bit here and there to achieve my objective. I'll let you know when I get them.
Old Jan 30, 2014 | 06:16 PM
7t9l82's Avatar
7t9l82
you will be very happy with those heads. very similar to what i did on mine. i did my own and had a buddy do the machine work , i did the grinding . i used an ngk plug but forget the heat range. if i can see it i will post back. good luck.
Old Jan 30, 2014 | 06:18 PM
7t9l82's Avatar
7t9l82
yes, just look at Edelbrock.
Old Jan 30, 2014 | 06:39 PM
Blazekillerace's Avatar
Blazekillerace
IMO, they are okay heads. I have them on my 383 that I ordered from Skip White Performance. But the hardware is not Pro Comp, just the heads themselves. I read that the weakest stuff is the hardware. But do what you think is best. I have seen badly made afr heads before, can't let a bad apple spoil the bunch though, but either way do what you think is best.
I personally do plan on replacing my pro-comp heads for maybe darts. Only if it's even worth it hp wise. Want a bigger cam . The pro-comp heads can be made to be reliable. Just not from the factory (From what I hear anyway). If you do plan on racing all the time. Make sure they are well built with good hardware instead of the crap they usually come with (again from what I've seen and read), or buy from a company that is "known" for good results. AFR, Darts, etc etc.
A lot of the posts here are informational. Some might be false. Either way best of luck .
Old Jan 30, 2014 | 08:02 PM
cv67's Avatar
cv67
St. Jude Donor '05
That dude scares me (YT vid)
Old Jan 30, 2014 | 08:34 PM
  #33
63mako's Avatar
63mako
St. Jude Donor '08-'09
This is a good thing having to do this to new heads?
Old Jan 30, 2014 | 10:18 PM
  #34
redvetracr's Avatar
redvetracr
If I was you I would google "pro comp aluminum head review" and then run Forest run
Old Jan 30, 2014 | 11:07 PM
  #35
Ibanez540r's Avatar
Ibanez540r
From the bit of research I've done, and I'm not as knowledgeable as a few of the others that have posted thus far, but these seem to be the best heads for around the $1000 mark. From what I've heard they are on par with AFRs.
http://www.profilerperformance.com/r.../sbc-23-degree
Old Jan 30, 2014 | 11:37 PM
  #36
7t9l82's Avatar
7t9l82
everything on the internet has to be right, doesn't it?
i know a lot of drag racers and street guys that run them with no problem, i will take their word over google anyway.
as long as someone competent goes thru them and install good components.
