Fan Clutch
Old Jan 19, 2014 | 07:24 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Default Fan Clutch
Looking for information on the fan clutch. I have my 77 Vette, was an L48 , but I have built a SBC that Mako and Billa believe will be making 400-420 HP. My fan clutch appears to be leaking, but not sure, it may be just dirt. SO I either need to get it rebuilt or buy another one.
I have bought at Dewitts aluminum radiator, Edelbrock Water Pump and want to stick with stock like thermostatic fan and stock fan shroud. With this equipment and a stronger motor, would I still want to install the same PN fan or switch to a different clutch. Also, I have heard these can be rebuilt, but really can't find anyone who does that. Finally, if buying new, any recommendations on where?
I have to admit, I really don't understand much about fan clutches.
Old Jan 19, 2014 | 09:45 PM
gcusmano74's Avatar
gcusmano74
The fan clutch is supposed to allow the fan to freewheel unless the engine is running very hot. Normally, you don't hear any fan noise (that is, the clutch is disengaged) unless the AC is on and it's very warm out. Very typically, if you shut off a warm engine, the fan clutch will allow the fan to spin for a couple of seconds after the engine has been shut off.
Old Jan 19, 2014 | 10:11 PM
speedreed8's Avatar
speedreed8
most auto parts stores (oriellyauto) have the HD therm. fan clutch. Hayden 2741. or Rock Auto has them also
ACDELCO Part # 154950 HD Thermal fan clutch
Old Jan 20, 2014 | 12:09 AM
7T1vette's Avatar
7T1vette
With a DeWitt's radiator (if it is sized to handle the increased engine power), the stock thermal fan unit should work fine. Be aware that if you install a lower temp thermostat than came with the car (195*F was the stock unit), that will not change the temp at which the thermostatic fan will begin to engage. If you want the fan to come on at a lower temp, you will have to buy a different fan clutch.
Old Jan 21, 2014 | 09:29 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I used the Hayden 2741 also. I don't have any cooling problems with the Stewart stage 2 pump, 180* ts, recored rad and oem 7 blade fan.
To Fan Clutch
