convertor stall options
Old Jan 20, 2014 | 04:44 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Default convertor stall options
planning on installing a 200r4 yet this winter. the 69 with the highly desired L46 350 300HP with 3:08 gears needs a little help out of the start gate. knowing the 200r4's first gear is a little lower I was thinking that a higher stall on the convertor would help also. so what do guys think would be a good choice. Thanks Terry
Old Jan 20, 2014 | 07:18 AM
scottw's Avatar
scottw
What do you use the car for? Driving on the road or 1/8-1/4 mile track?
If mainly road use, I wouldn't go much over 2.2K. If track use, 3K.
Old Jan 20, 2014 | 08:40 AM
Street Rat's Avatar
Street Rat
Call a converter manufacturer and get a recommendation according to your engine, drive train, cam selection, etc. They can give you your best choices.
Old Jan 20, 2014 | 09:55 AM
hugie82's Avatar
hugie82
With a highway rear and a fairly low 1st gear I think a 2300 stall would be an all around good street burner! 2300 and down stall converters are much cheaper and I'm pretty sure you can still maintain the lock up function.
Old Jan 20, 2014 | 10:07 AM
gkull's Avatar
gkull
You want an efficient light weight 9.5 inch Vigilante. They are so efficient that lockup only changes a couple hundred rpm. I drove mine for 2 years with no lockup function.
With hardly any power I would get a 3000 because these kind don't slip like cheap TC's that most people are familiar with
Old Jan 21, 2014 | 12:21 AM
pricesgarage's Avatar
pricesgarage
just use a 2000 rpm 82 from a 82 vette 700r4 they use a 27 spline
Old Jan 21, 2014 | 06:02 AM
terrys6t8roadster
thanks that's the info I was in need of.
Old Jan 22, 2014 | 02:40 PM
gkull's Avatar
gkull
They also weigh like a boat anchor and being very inefficient turn HP into heat. 1982 was the first year of the 700R4 and the tranies didn't last very long. Junk from 30+ years ago?
It is also like putting a 40 lbs fly wheel on a stick car.
You ever heard about going to lighter flywheels? It is the same thing with a TC
Old Jan 23, 2014 | 11:21 PM
couperdecar's Avatar
couperdecar
I vote for 3000 stall with a lockup. Made a world of difference for me. You don't even know its a high stall - until you need it. And get a good tranny cooler.
To convertor stall options
