removing exhaust heat riser valve
Old Jan 22, 2014 | 02:10 PM
johnnybrewmeister's Avatar
johnnybrewmeister
Default removing exhaust heat riser valve
I've read a bunch of old posts about what this is, how it works, and whether or not it is needed. I've decided it's not for So.Cal, and mine is pretty rusty and not so smooth in opening/closing. So I'm thinking of removing it.
Here's my questions:
1) do I really need to buy a pricy ($30-50) spacer to put in it's place?
2) can't I just bolt up the passenger side the same as the driver's side?
There seems to be enough slop in my tired old exhaust pipes (engine is currently out) that would make up for the 1" lost by removing the heat riser.
Or would removing it tweak the angle of manifold/donut meeting up with exhaust pipe that would not get a good seal?
'nuther options is gutting the riser and plugging the axle holes, but I like K.I.S.S.
Thanks,
John.
Old Jan 22, 2014 | 02:43 PM
hugie82's Avatar
hugie82
The spring always rusts and breaks. We use to take them off and knock or cut the pin out to remove the flap. Then weld the holes on both side.
They were designed to help the car warm up faster.
Old Jan 22, 2014 | 02:50 PM
kjbuster1's Avatar
kjbuster1
Default spacer
Thanks,
John.
I've run a '65 396 and /66 with 454 with out the valve and without any problems. Used a spacer though.
Old Jan 22, 2014 | 03:38 PM
rponfick's Avatar
rponfick
John, as been suggested, you can save the cost of a spacer by removing the flapper valve from the inside of the unit. Plug pivot holes and you are good to go.
Ralph
Old Jan 22, 2014 | 04:37 PM
Paul L's Avatar
Paul L
Gut it and plug holes with muffler cement. A $5.00 solution. I would not omit it and start bending the exhaust pipe to "fit".
Old Jan 22, 2014 | 05:07 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Drilling and tapping the holes for plugs is another option if you don't have access to a welder. You need a spacer.
Old Jan 22, 2014 | 09:04 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Have u ever welded cast iron Mick? Good luck!
Old Jan 22, 2014 | 09:09 PM
johnnybrewmeister
Aha, good to know, thanks everybody.
I don't weld, but was thinking I could try to find a local shop.
I don't have a tap set, so even that option was looking costly to buy the tools.
I hadn't even thought about muffler cement; I'll do some googling...
Favorite brand? I guess I'll also go down the path of a local weld shop.
Old Jan 22, 2014 | 09:11 PM
speedreed8's Avatar
speedreed8
dont try and run without the spacer, pulling the pipe up by the bolts will stress the ex. manifold outlet and it will crack!.... i know. i have mine installed but its gutted and a muffler shop welded the holes up for me...$10
Old Jan 22, 2014 | 09:26 PM
7T1vette's Avatar
7T1vette
Drop the right-side exhaust pipe and use your Dremel to cut the flapper rivets off the shaft. Everything outside remains the same.
Old Jan 22, 2014 | 11:16 PM
Mick71's Avatar
Mick71
No welder here. Just read it in another post.^
Old Jan 22, 2014 | 11:28 PM
chevygod's Avatar
chevygod
Dunno about Corvette ramshorn manifolds but many Chevy manifolds used with the riser are not machined to accept an exhaust donut, so can't be sealed as well. Another issue besides the stressing of the pipe/manifold...
The flapper can be removed from the assembly with the shaft left intact (done that) or the flapper and shaft can be removed and the appropriate sized hammer-in plugs (like small freeze plugs) or dowel pins can be pressed or hammered in (done that too). These may require a correctly sized drilled hole, but easier than welding or tapping for some.
Good luck
Tom
Old Jan 23, 2014 | 01:45 AM
cardo0's Avatar
cardo0
Welding cast iron requires heating to 400*F and using either special nickel rod for stick welding or cast iron filler rod with plenty of flux using Oxy/Acetylene (gas).
cardo0
Old Jan 23, 2014 | 04:28 AM
nz corvette's Avatar
nz corvette
Right on,7T1Vette
Old Jan 23, 2014 | 10:41 PM
johnnybrewmeister
Good luck
Tom
Interesting, Tom and 7T1vette both mention leaving the shaft intact. Clearly this would be better than what I have now, but what about the shaft itself impacting airflow. Is zero obstruction of air-flow worth it to take the shaft out? More work to plug/weld/putty the holes (bummer), but better airflow with less turbulence (bonus). It would be good to do this only once...just over-thinking my options.
Old Jan 24, 2014 | 10:55 AM
thegazman's Avatar
thegazman
Default thegazman
If you are worried about airflow restriction from the shaft, buy the blank spacer for $29.00. That's what I did. What every you do, buy new gaskets.
Old Jan 24, 2014 | 04:00 PM
7T1vette's Avatar
7T1vette
Every 'stock' C3 ever built has a heat riser valve [and shaft] in it which presents some blockage to exhaust flow. If you need to improve exhaust flow, install larger headers WITHOUT the heat riser in it. Otherwise, the stock stuff was designed to provide adequate exhaust flow under all NORMAL operating conditions...even wide-open-throttle.
To removing exhaust heat riser valve
Old Jan 24, 2014 | 05:16 PM
gcusmano74's Avatar
gcusmano74
Or you could just give the shaft end a few squirts of WD40 when it's cold and loosen it up so that it works nicely. Then close the hood and just drive it.
Seriously, if you have a cast iron manifold and a "divorced" choke, (with the bimetal spring bolted to the manifold), I wouldn't do more than that. Because otherwise it will take about forever for the choke to come off after a cold start.
If you have an aluminum manifold, you could probably get away with removing the heat riser. Or if your car has an electric choke.
Remember what Boss Kettering said, "Parts left out cost nothing and pose no service problems."
If Chevrolet thought it was necessary to have some sort of manifold heat, I'd leave it be.
Old Jan 24, 2014 | 05:49 PM
7t9l82's Avatar
7t9l82
exhaust heat is not necessary , it was used to make it easier for the average person to drive off in a cold car .
Old Jan 24, 2014 | 07:00 PM
7T1vette's Avatar
7T1vette
I've seen/owned a lot of old cars with heat riser valves. Nearly all of them have had the riser valve stick at some time or other. I have never been successful at lubricating a stuck valve to free it for more than a few days. Once they get corroded enough to stick, they appear to be "doomed". I think the valve would have to be removed completely, cleaned and the shaft polished, to have any shot at it being viable for very long. If GM really wanted these things to last very long, the shaft should have been made of stainless and the manifold should have had stainless bushings for the shaft.
But then, GM designed the car for about a 5-10 year [first] life span.
