Really!? Is this even possible..
Old Jan 31, 2014 | 01:25 AM
Ibanez540r's Avatar
Ibanez540r
Originally Posted by Tim 1973
No, start at a distance once the powder gets sticky you can move closer... Takes a little practice so just grab some scrap metal and try it. My heat does not have a strong blower in it..
Because I'll be working in a cold garage, other then running a turbo heater for a bit, I'll probably pre-heat the area. Once I spray the powder it will tack up anyway, so the heat gun should work well. I have a laser temp gun so I'll be able to adjust as necessary to keep my cure temp accurate.
