Steering Column
Old Jan 29, 2014 | 06:16 PM
mountainman924's Avatar
mountainman924
1st Gear
Default Steering Column
I am building a custom 76 vette. I am going with a keyless start. I am looking for a shroud that would cover the key but also have the tilt. Does anyone know where I might find this shroud.
Old Jan 29, 2014 | 06:28 PM
DUB's Avatar
DUB
I would not know even where to start. Finding a tilt column with no ignition key provision would have to be before a 1969.
DUB
Old Jan 29, 2014 | 07:04 PM
Ibanez540r's Avatar
Ibanez540r
I'd imagine you will not find one. Probably have to modify the one you have. Maybe cut the lip for the hole, cover it smooth and cast a fiberglass mold.
Old Jan 29, 2014 | 07:33 PM
noonie's Avatar
noonie
Making your own is probably best.
If you really want to play...
Go all out and put a TBird break-away column in.
These none locking columns:
GM pre 69 cars, pre72 trucks
Chrysler and AMC pre 70
Ford pre 70 cars, pre 79 trucks. pre 92 vans
Jeep pre 74
I think it's easier to use a 67-69 column for sector shaft compatibility without the need for a special ujoint or rag joint.
You also need a column from a floor shift car.
I would count on some welding for a proper fit.
To Steering Column
