need an assembled head
1. What assembled heads on the market will work with this cam?
2. Will I need to replace the valve springs on the assembled heads?
3. Will this give me ok vac?
Thank you
Cal
If you're buying rockers too consider 1.6 ratio to help feed your 383.
I'm guessing this isn't a budget redo so you may consider the best - AFR. Call them with your needs and have them spec your cam too. You can never go wrong with the best !!
you have the gearing for a bigger cam/ higher operating range. A 350 to a 400 drops your operating range 500 RPM so when selecting a cam keep this in mind. AFR is the best and they will set the head up with the exact springs you need. Power potential is all in the heads.
I am fairly flexible on budget, I will spend the money if I need to, however I plan on making this a driver, no racing except I want a little when I get on it. So I may accept a Modern Sportsman head over a AFR if I saved several hundred and had to give up a little. But unless there is a significant savings I will spend a little more. This forum really helps me figure out what I want, you guys are great, all info helps me. This cars not for racing, but I want it to work well and sound good, I will not be over 6000 much. That's why the Comp Cam roller 264 looked about as much as thought I could go. Learning more here however.
does this help a little more
thanks again
cal
thanks again
cal
http://www.compcams.com/Pages/401/dyno-sheets.aspx
and scroll down to the roller cams. Figure dropping about 400 RPM on any cam on this chart since you going 383 instead of 350. The bigger CI will also increase vacuum with a given cam. The cam you selected flattens out @ about 4000 RPM. This converts to about 3600 in your engine. It is restricting the ability to fill the cylinder at upper midrange RPM due to the lower duration. You buy good heads to increase power production. Don't restrict the heads ability to make power by restricting flow. Good heads will make more power across the entire RPM range. I would shoot for around 10 to 1 or a little under compression and, with your 5 speed and 3.55 gears go with something like the XR276HR on this chart. Remember to figure the difference of about 400 RPM less across the board. See the power difference @ 2500 RPM? (2100) in your build, Also look at the torque peak and rpm range above 400 ft lbs, again backing everything off about 400 RPM. The 276 is noticeably higher and gains from 2000 to redline over the 264 exponentially. Also notice the point where power flattens out, even the 276 will hit the wall at a little over 5000 rpm in a 383. Do not be afraid of a loss at the bottom end. The 383 combined with the 3.55 gears and 5 speed will allow you to have good bottom end, get into the powerband quick, still pull decent vacuum and be very docile in everyday driving yet make good use of your upgrade heads and make increasingly more power as it accelerates. I would recommend the AFR 195 eliminators for your combination. No replacement for quality heads, they make more power everywhere. Also 1.6 rockers will not change the operating range but will help good heads fill the cylinders, they will like the extra lift and increase power from off idle and up. The Dyno charts are actually misleading because all are on a 350 with 9.25 to 1 compression. As you go bigger on the cam you can increase compression making more power across the board hence the 10 to 1 recommendation. The engine used is actually losing DCR (and cylinder pressure) as they upgrade cams so your results will increase compared to theirs. Take it for what it's worth.
I am still checking out heads, I have found a set of Sportsman 11 heads assembled (the new technology) with the correct springs for several several hundred dollars less than the AFR's. Based on my needs is the savings worth it over the AFRs.
thanks
cal
thanks
cal
thanks
cal
AFR 195.....................211 intake 175 exhaust
Sportsman II .............182 intake 128 exhaust
Flow @ .500 lift
AFR 195 CC.................285 intake 219 exhaust
Sportsman II 200 CC ...257 intake 160 exhaust
AFR Aluminum, Sportsman II Iron
Your call. I would go AFR no doubt. Flow on the exhaust side is as important for making power as flow on the intake side.
Edit: Add Trickflow 195
Flow @ .300.................196 intake 135 exhaust
Flow @ .500 ................249 intake 186 exhaust
Here is head flow info: http://users.erols.com/srweiss/tablehdc.htm#Chevy
Flow being only 1 area of importance. And it seams all anyone ever goes by and that is not the end all of which head is better.
I suggest the fast burns , shop for them the prices can be really good. I got a new set in boxes off racing junk for 850.00 shipped ... And on my 350 i get 383 hp/ tq all day long and the only 383 i have lost to was in a 2700 pound S-10 truck..
The new GM 383 is rated 450/450 with what many would call a mild cam that says a lot , the cam in my 350 is mild as well , she idles like kitten screams like a lion and that is all because of these heads.
For a 425 to 500HP you can spend around $1800 for a kit. For 550 plus you will spend around $2500. Just note the more HP the less "manners" the engine will have.
Flow numbers on the 210 port fastburn:
Flow @ .300............... 177 intake/124 exhaust
Flow @ .500................223 intake/166 exhaust
What intake are you using that matches the ports and fits under the stock hood?
GM performance parts testing shows substantially higher flow numbers.
http://www.hotrod.com/techarticles/e...ylinder_heads/
This is where AFR excels. Their 180 eliminator flows more than most 200+ cc Heads on the market. Port velocity helps bottom end torque. I/E ratio is another strong point as well as lightweight valvetrain components. If budget is not the primary driver buy AFR. If budget has no bearing at all buy the AFR Competition ported 195 eliminators for about $2000. They flow 300CFM and are capable of close to 600 HP with a 195 port. If budget is the primary driver look at the Straub heads. They seem to be the best bang for the buck in a budget aluminum head.
