sbc fuel pump plate
Old Jan 31, 2014 | 02:49 PM
20mercury's Avatar
20mercury
Default sbc fuel pump plate
I need to replace the fuel pump on a 72 LT-1 sbc as the body is leaking and was wondering if I need to replace the fuel pump plate at the same time? what does the fuel pump plate do and how could you tell if it needs to be replaced.
Thanks!
Old Jan 31, 2014 | 03:02 PM
jnb5101's Avatar
jnb5101
leave the plate alone. as far as i call tell, the plate only has to be removed to access the fuel push rod.
Old Jan 31, 2014 | 03:21 PM
Alan 71's Avatar
Alan 71
Hi 20,
Since you'll have the fuel pump off it's just 2 more bolts to remove the plate.
I think I'd do it to replace the gasket between the plate and block.
Upper 2 bolts are for the pump and lower 2 for the plate.
Regards,
Alan
Old Jan 31, 2014 | 03:22 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
You beat me to it, Alan. If it leaks it is a mess and not handy to fix.
Old Jan 31, 2014 | 03:32 PM
dochorsepower's Avatar
dochorsepower
And the next question is . . . how do you keep the fuel pump push rod in place to install the fuel pump? Heavy grease!
Old Jan 31, 2014 | 04:52 PM
CaseyJones's Avatar
CaseyJones
Or insert a long bolt through the front access in the block to hold it. Finger-tight is all you need.
Old Jan 31, 2014 | 05:28 PM
Paul L's Avatar
Paul L
Either heavy grease or the bolt in front will do. Make sure the camshaft is in a position where the push rod can be fully inserted. You don't want to be fighting that rod against the pump spring when you button up the pump attachment bolts.
And yes take the plate off and use a gasket with a sealing compound such as Permatex Aviation Form-a-Gasket. It seals very nicely. If you have A/C you don't want to repeat that job because of a leak. The pump is inaccessible from the top.
Old Jan 31, 2014 | 06:26 PM
20mercury's Avatar
20mercury
Default Ok and much thanks!
Ok and much thanks for all of the great advice!
To sbc fuel pump plate
