Brake Parts
Old Feb 2, 2014 | 10:41 PM
Vettes Rule's Avatar
Vettes Rule
Default Brake Parts
Going to rebuild brakes on 1981. New calipers, master cylinder, booster....etc. Where should I buy. O'Reilly's or one of the forum vendors? O'Reilly's cheap but gut says no.
Old Feb 2, 2014 | 11:17 PM
noonie's Avatar
noonie
I use local stores all the time whenever I can. Those brake parts are nothing special. No killer shipping either.
Old Feb 2, 2014 | 11:50 PM
garnercur's Avatar
garnercur
In the process of doing so right now, also on an 81. Depends on what resources you have/the condition of your brake system. A couple general rules of thumb I've picked up combing through here:
Master Cylinder: If the bore/reservoir is rusted (especially if it's pitted) you probably need a new one. They're pretty cheap on ebay.
Brake Boosters rarely fail, unless you know of a preexisting issue
Brake pads definitely need to be replaced. Probably your e-brake pads, too.
Upgrade to stainless steel brakelines, get some new trailing arms
If your calipers are not rusted beyond repair (pitted), you can refinish them with a sandblaster and a rebuild kit. If not, you can send your old ones in for a core charge to most places and get new ones. I used vette brakes and products.
Replacing your brake pipes and distributors depend on their condition.
Hope that helps!
Old Feb 2, 2014 | 11:51 PM
garnercur's Avatar
garnercur
Oh also the original rotors can probably be honed if they haven't before, otherwise they're about 160-200 bucks. Just make sure the diameter stays within spec
Old Feb 3, 2014 | 12:03 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Vette Brake @ Products. T
Old Feb 3, 2014 | 11:02 AM
Vettes Rule
Default Brakes
Hope that helps!
Thanks. Brake booster i agree. But car been sitting for five years.
Old Feb 3, 2014 | 11:23 AM
garnercur's Avatar
garnercur
Mine was sitting for 15, we'll find out if the booster is operational when I bleed the system! haha
Old Feb 3, 2014 | 12:07 PM
Marlin's Avatar
Marlin
My 73 sat for several years. When I opened the calipers it was a lot of gunk in there.
I rebuilt my 4 calipers (O-rings not lip seal), replaced all the rotors, brake hoses, carbon metallic pads, and 2 small rear brake lines. The master cylinder and booster both still seem fine for now.
Old Feb 3, 2014 | 01:22 PM
redvetracr's Avatar
redvetracr
you won`t get calipers with o-rings from an auto parts store but if your satisfied with standard lip seals Auto Zone is a good choice, no return shipping charge on the cores either...
Old Feb 3, 2014 | 01:40 PM
Vettes Rule
All I needed to hear. Do not want lip seals.
Old Feb 3, 2014 | 01:48 PM
qwank's Avatar
qwank
nothing wrong with lip seals if your calipers are stainless steel sleeved
Old Feb 3, 2014 | 01:58 PM
Marlin's Avatar
Marlin
My calipers are stainless steel sleeved and the lips seals sucked...
Old Feb 3, 2014 | 06:54 PM
Vettes Rule
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
What ya'll think?
Old Feb 3, 2014 | 07:45 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
PM sent to you.
Old Feb 3, 2014 | 08:12 PM
garnercur's Avatar
garnercur
Originally Posted by Vettes Rule
Thats a great deal, the only thing I would suggest, as stated before, is requesting that they upgrade your brake lines to stainless steel over rubber. Its a little more expensive, but offers great peace of mind.
Old Feb 18, 2014 | 05:08 AM
M-yellow01's Avatar
M-yellow01
I'm sure that the auto zone calipers are not stainless steel sleeved. In their description, they only say that they're metal pistons. What do you guys think? Maybe SS sleeves?
Old Feb 18, 2014 | 07:20 AM
noonie's Avatar
noonie
They have been for years.
To Brake Parts
Old Feb 18, 2014 | 08:03 AM
Street Rat's Avatar
Street Rat
Old Feb 18, 2014 | 02:52 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default old rotors
I must be taking good care of my original owner 1968 convertible with about 98,000 miles. Same brake rotors since the 68 left the factory. Same emergency brake shoes and is used every time I drive it. Same with my 1970 original owner with over 160,000 miles.
Old Feb 28, 2014 | 05:40 AM
M-yellow01's Avatar
M-yellow01
I had a leaking rear caliper on my 75, without power brakes. The brake started to stick, so I took off the capiper yesterday. Expecting to find lip seals. I found o-ring seals with ss sleeves, that were in great shape. Only one piston was leaking and that one was full of gunk. Cleaned the entire caliper out and put it back on. Bleed the brake caliper, but the pedal is low and soft. Are you supposed to bleed both sides of caliper? I only used the bleeder nut the furthest from the incoming brake line. Thanks
