Vortec heads coming soon!
Old Feb 22, 2014 | 08:18 PM
  #141
7t9l82's Avatar
7t9l82
well you have blue valve springs and vortec heads , that should make Priya happy
Old Feb 22, 2014 | 10:12 PM
  #142
Priya's Avatar
Priya
It'll have to do
Old Feb 25, 2014 | 08:51 PM
  #143
Florida 79's Avatar
Florida 79
Default Radiator finally out
Ok, been slowly getting things apart. Doing alot of PB Blaster, trying not to round off or strip out anything. So far so good. Got a little stuck on the passenger side lower radiator support bolt. But finally got it.
I found that I had no working lower steering bearing, or anything else down at the bottom of my steering column. Ordered parts from Zip Corvette. Only been two days, hopefully coming soon. Also ordered a new harmonic balancer and some gaskets from Jegs.
The radiator is all out and the condenser is out and the radiator support looks like crap. Well, it looks 35 years old. Pretty rusty on the bottom. Not sure about the repair. Maybe I'll shop a bit before putting in.
Working on the A/C and heat (I know, kind of funny saying that I want the heater to work) next.
Old Feb 25, 2014 | 09:39 PM
  #144
scottyp99's Avatar
scottyp99
Uh-oh! Looks like you have contracted "while-I'm-at-it-itis"! Don't worry, it's a good disease to have if you have the time and money. There is no better time to take care of these issues than right now, with that pesky engine out of the way.
I am enjoying the saga! Keep those pics and updates coming!
Scott
Old Feb 26, 2014 | 09:28 AM
  #145
commander_47's Avatar
commander_47
While-I'm-at-it-I-tis is a good thing to have. I probably went overboard, but don't regret it.
I replaced everything to include the fan motor, wiper motor, windshield washer motor, heater valve, the front brake line that goes under the front of the motor, and the radiator.
I just do not want to have to go back into those nooks and crannies later to fix some small thing.
At the time I thought I really wanted to keep the Air Conditioning, and went ahead and rebuilt and converted the entire system.
I didn't turn it on one time last summer.
If I was to do it again, I would probably remove the A/C. Need the heat and defroster, which is all new in my car, but it would really clean up the engine compartment without all that A/C stuff.
Old Feb 26, 2014 | 09:42 AM
  #146
7t9l82's Avatar
7t9l82
this last week or so the need for a heater is obvious. still not that bad though.
Old Feb 26, 2014 | 11:52 AM
  #147
bluedawg's Avatar
bluedawg
Were do you live?
Old Feb 26, 2014 | 01:32 PM
  #148
7t9l82's Avatar
7t9l82
believe it or not florida! got chilly a couple nights , but not like you guys.
Old Feb 28, 2014 | 08:42 PM
  #149
Florida 79's Avatar
Florida 79
The wife says "make the A/C work". It does get hot in Florida. Trying to decide about heat actually. The heater core has never been hooked up.
Anyways... Got the new radiator ordered. Got in all the lower steering bearing parts, except the washer (you know the first thing that goes in). Come on Zip Corvette, help me out! The rest of it was pretty straight forward, but you do have to press the new bearing into the adapter (the white plastic part). Wasn't sure about it, but it made since and fit (vise).
The engine is almost together, put the new harmonic balancer on today (Professional Products 80002). Installed the water pump, fuel pump and distributor.
The pics show the lower steering bearing parts. The new intake manifold that came with the heads, thanks Scoggins Dickey. The engine as it is now. Gotta clean up the radiator core support, at $320, too much to bite right now.
Old Feb 28, 2014 | 08:45 PM
  #150
Florida 79's Avatar
Florida 79
And no, those aren't the valve covers, those are the old one's. Just trying to keep spiders out. Oh, the Fel-Pro Perma Dry oil pan gasket was used. It's a one piece (blue) unit that seems to be a great idea.
Old Feb 28, 2014 | 08:55 PM
  #151
MrJlr's Avatar
MrJlr
Looking real good.
Old Feb 28, 2014 | 09:13 PM
  #152
PeteZO6's Avatar
PeteZO6
Looking good! Paint your pulleys satin or semi-gloss black.
Pete
Old Feb 28, 2014 | 10:06 PM
  #153
cv67's Avatar
cv67
St. Jude Donor '05
May as well make it all work while its apart
something about knowing it all works even if you dont use it makes it more satisfying to own.
Old Mar 1, 2014 | 10:11 AM
  #154
scottyp99's Avatar
scottyp99
Get the heat working. Even if you never use it, there is just something satisfying about having everything work as it should.
Scott
Old Mar 1, 2014 | 05:48 PM
  #155
Florida 79's Avatar
Florida 79
I've got the VHT semi-gloss for under the hood and the pulleys and brackets. Just cleaning and sanding (I hate cleaning and sanding). I'd love to drive it...
Anyways, still thinking about the radiator core support. It's sure ugly, might order a new one Monday. What's another couple hundred, huh?
Old Mar 1, 2014 | 09:26 PM
  #156
scottyp99's Avatar
scottyp99
There's only one thing you need to know about rust: It ain't gonna get any better on its own. Ya gotta fix it or replace it. Good luck!
Scott
Old Mar 2, 2014 | 11:34 PM
  #157
Florida 79's Avatar
Florida 79
Went to Webster today...anybody...first Sunday of the month, big parts meet. Anyways, yes I bought flea market valve covers, I like 'em, paid less than $50.
Opened up the "doghouse" which contains the evaporator. Wow, the picture is worth all the words I can express. Goes with the theory that my car sat for a long time. The more I drive the better it runs.
To Vortec heads coming soon!
Old Mar 3, 2014 | 12:21 AM
  #158
Florida 79's Avatar
Florida 79
And yes, they're just stamped out, but they look good. Of course the new throttle cable support wouldn't go down (it's always something). So, I drilled the holes on the throttle cable support larger to move it over about 3 mm to clear the thicker valve cover. Seems to work now.
Last edited by Florida 79; Mar 4, 2014 at 07:32 PM. Reason: Wrong info, not billet.
Old Mar 3, 2014 | 08:41 AM
  #159
scottyp99's Avatar
scottyp99
One thing I noticed after putting bigger valve covers on my small block was that I had a hard time getting at the distributor hold-down bolt. How's that look? BTW, nice score with the valve covers. They're pretty sharp looking. They don't look like billet, but sometimes you can lose some detail in pics, I'll take your word for it!Those center-bolt covers have a reputation for sealing really well, which seems to be a perennial problem with the perimeter bolt covers.
Scott
Old Mar 3, 2014 | 03:28 PM
  #160
Florida 79's Avatar
Florida 79
Thanks for your input Scott,
I think it's billet, very heavy, I like that. Compared to the tin can, stamped out covers, this one had a lot of body to it. Installed the two baffles, but may remove the one on the intake (filter side) of the PCV system to allow easier oil addition.
Trying to pressure test the evaporator and heater core using balloons. I know it's not the best way, but I believe it will show a major leak. As always, time will tell. So far they both appear to be ok.
With the bird nest gone, I'll seal up the doghouse and hook up everything.
Trying to decide whether to buy the Eckler's A/C and heater seals or just get some monkey poop and seal it up.
Decisions decisions.
Oh, by the way it's 82 degrees in Florida. Can you say summer time?
