Low idle vacuum
Old Feb 9, 2014 | 09:39 PM
PeteZO6's Avatar
PeteZO6
Originally Posted by greghennings
I hope this works, with the way websites are built now-a-days you know how hard it is got get anything done when your internet is stuck in dial-up speed .
Anyway, i had this set up the square gasket on bottom, spacer, round gasket, carb.
I'm a little confused here. You say you have a Holley DP, but to me that manifold looks like one for a spread-bore Q-jet. Seems like that would be a huge mismatch causing a big vacuum leak.
Pete
Old Feb 10, 2014 | 12:48 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Well....for sure, the square gasket is not the correct one because there is no strip of gasket material in the middle of the square opening---causing an internal leak between the D.P. wall and the spacer---causing the divider wall to be useless....(but that problem should not cause a vacuum loss)
ask me how I know.................................... ..
and yes....some folks like a dual plane "leak"....similar to an exhaust system with a cross-over pipe.
Old Feb 10, 2014 | 08:13 PM
greghennings's Avatar
greghennings
some how gas was getting out of those gaskets and pooling up in the intake manifold "valleys". Both gaskets were completely soaked. Should a guy be using a gasket sealer on these?
I can see now i've got a compatibility issue. The holley and intake were on the car when i bought it, the gasket set between the two before was cobbled terribly. I wonder if i could just use another "4 hole" gasket on the bottom and be ok. I see there's some adapter kits, but i haven't read anything good about them. But it doesn't look like this is my problem anyway?
I do need the 1/2" spacer to clear the brass fitting you see between the intake port and the distributor.
I would have gone to a C5, but i was having a hard time selling it to the old lady despite the fact she told me i could have a corvette. So i had to trade my 99 firebird for a corvette that i could get bought for equal value. But i wanted something to work on anyway, there isn't much to mess with on a newer corvette.
Old Feb 10, 2014 | 08:41 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
In addition to the great advice available here, check out this primer on reading a vacuum gauge:
http://www.secondchancegarage.com/public/186.cfm
Old Feb 10, 2014 | 10:27 PM
PeteZO6's Avatar
PeteZO6
From what I can see you need an adapter to mount a Holley carb to that manifold. Like this one:http://www.summitracing.com/search/b...-bore-4-barrel
That should solve your vacuum leak and your clearance for the vacuum fitting problems.
Pete
Old Feb 11, 2014 | 10:21 AM
lars's Avatar
lars
The manifold shown is a dual-pattern manifold intended to mount either a Q-Jet or a Holley (note the 8 mountning stud locations for the dual pattern). Either carb can be used without an adapter, as long as the gasket used seals around the perimeter of the flange with full contact and no air gap. This can be a problem around the secondary side, though.
No, you don't use a sealer. The gasket has nothing to do with the wetting issue. If the gasket is fuel soaked, it is because your carb is dripping fuel after shutdown from the main discharge orifices or from the accel pump shooters. This fuel will puddle on the throttle plates and wick out the shafts and onto your manifold, wetting the gasket in the process. You need to identify and fix your carb fuel leakage problem.
Lars
Old Feb 15, 2014 | 10:46 AM
greghennings
Having reviewed the link claysmoker provided under scenario 12 is exactly where I'm at. I took a small gamble and bought two new identical carb gaskets that have the 4 round holes. Install proved slight results, the vacuum gauge no longer bounce between 3 & 5 but still on 3. Increasing engine speed brings it up to 8, but solid. I have my timing now set to 18/36.
It started perfectly, barely any choke, and with a slight tweak of my distributor ran better than ever. But still no vacuum, I've been suggested to just install an electric vacuum pump. It might be masking the problem, but I don't know how big of a problem we're taking about when the engine starts and runs great.
Old Feb 15, 2014 | 11:24 AM
Mike Ward's Avatar
Mike Ward
You sure you're not measuring vacuum from one of the 'ported' sources? Needs to be full time vacuum.
The external gas leak sounds like excessive fuel pressure or a stuck float.
Old Feb 15, 2014 | 02:21 PM
diehrd's Avatar
diehrd
http://www.alldatadiy.com/alldatadiy...8162/145134835
Old Feb 15, 2014 | 03:03 PM
v2racing's Avatar
v2racing
I'll repeat myself from post no. 14.
The one thing I would add is do a compression test or leak down test to make sure you have a healthy engine. If the compression is way low or leak down is way high, you are beating your head against the wall.
Old Feb 15, 2014 | 03:19 PM
scottyp99's Avatar
scottyp99
I have the same intake manifold (Performer 2101) and a square bore carb (Holley 1850). If you take a good look at the impression on the gasket below the spacer, I am sure that you will notice a spot on the driver's side, where the secondaries are, that just barely covers the intake manifold, probably by less than 1/8", maybe even less...maybe not at all. You really need an adapter, like this:
http://www.summitracing.com/parts/sum-g1420/overview/
I couldn't find one that wasn't open, so I made one with 4 holes, and also made my own gasket, to keep both sides of the manifold separated. Also, I know a lot of folks say don't use a gasket sealer on carb gaskets, but I have had good luck with this:
http://www.permatex.com/products-2/p...sealant-detail
Good luck, and definitely let us know when you figure it out.
Scott
Scott
Old Feb 15, 2014 | 06:08 PM
greghennings
I purchased a compression gauge, all cylinders are between 150-155, actually better than I expected, but the car only has 60k miles so the cylinders or valves shouldn't be toast. I didn't pick anything up to do the leak down test.
Yeah Scotty I see what you're talking about on the driver side of the manifold, it its close.
After doing my compression test I ran it, this time I put the vacuum gauge on the brake booster line, and I get an erratic 5-8 inches, if I rev the motor up I can get it almost to 20. But it doesn't hang in there. But, prior to before, removing the primary vacuum line off the carb did nothing, but now if I remove it the engine revs up. This whole thing doesn't make sense.
Old Feb 15, 2014 | 06:48 PM
  #33
scottyp99's Avatar
scottyp99
I like Holley carbs, but they can get a little wonky after a few years, and need a rebuild. How long has it been? Also, why would you paint a nice-looking aluminum intake manifold?
Scott
Old Feb 15, 2014 | 09:39 PM
  #34
greghennings
Scott
That's a good question Scotty ��, and I'm a huge fan of polished aluminum (I have two fords both ingot aluminum paint) but the intake just didn't float my boat I guess. And I figured that paint probably didn't stick that great to it so I'm sure I can take it off someday if I want to.
I have not rebuilt this carb, and if I had to guess its never been redone. It was installed in 1992. I suppose it wouldn't hurt to do it...
Old Feb 15, 2014 | 10:00 PM
  #35
scottyp99's Avatar
scottyp99
It's your intake, you can do whatever your heart desires with it!
If you've never rebuilt a Holley before, here's a great article describing the disassembly, cleaning, and reassembly of a double pumper. It's easy. If Holley carbs were any easier to disassemble and reassemble, they'd have to be made of Legos.
http://www.fordmuscle.com/archives/1.../index.php#mid
It may not fix your problem, but at least you'll have ruled out one more thing, and it probably needs it anyway. Plus, it's kinds fun, I think. Like a jigsaw puzzle...sorta.
Scott
Old Feb 15, 2014 | 10:45 PM
  #36
PeteZO6's Avatar
PeteZO6
Scott
Not to rain on your parade Scott, but that article is flat wrong out of the box. Third paragraph states that both mechanical secondary AND vacuum secondary 4150 carbs have dual accelerator pumps. Not so. Double pumpers all have mechanical secondaries; vacuum secondary carbs don't. When an article makes that gross an error, I tend to distrust the entire article. And I like Fords
Pete
Old Feb 15, 2014 | 11:44 PM
  #37
diehrd's Avatar
diehrd
Can you check to see if the carb bowl is resting on that rear brass vacuum fitting , It can fool you on some cars in that the carb will feel 100% down when in fact it is a wee bit up on that vacuum connection
To Low idle vacuum
Old Feb 16, 2014 | 01:04 AM
  #38
v2racing's Avatar
v2racing
Can you video or at least get an audio recording of the idle so some educated ears can hear it?
Old Feb 16, 2014 | 09:32 AM
  #39
scottyp99's Avatar
scottyp99
Pete
"Double pumpers all have mechanical secondaries; vacuum secondary carbs don't."
Yes, the sentence before the one you are criticizing even states this, contradicting itself. It's a minor error, the OP has a double pumper and knows it, so it shouldn't cause him any confusion during the rebuild. Still, bad info is bad info.
Scott
Scott
Old Feb 22, 2014 | 05:34 PM
  #40
greghennings
i'm going to have to pull it off again, she's leaking gas just sitting there again, i'll just rebuild this carb as i get time. Before i pull it off, any chance i could find a vacuum leak around where the distributor goes through the intake manifold? There was a gasket i installed for it but maybe that's not sealing? I keep forgetting to get some carb cleaner bought to check the thing...
