Driveline angle?
Old Feb 8, 2014 | 07:07 PM
CWerner's Avatar
CWerner
Default Driveline angle?
On my LS swap, I've just completed installing the driveshaft. What is the final driveline spec? Is it + - 2 degrees?
Old Feb 8, 2014 | 07:11 PM
Garys 68's Avatar
Garys 68
2 degrees is way out.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
Old Feb 8, 2014 | 07:31 PM
CWerner's Avatar
CWerner
Wow, I hope I don't fail the test after reading that.
My driveshaft is sitting at 1.5 degrees from level. Is that good or bad or okay? I thought I saw in that document showing 1-1.5 as the spec.
Old Feb 8, 2014 | 07:48 PM
ignatz's Avatar
ignatz
There is more to it than just the driveshaft angle. Have a look here
http://forums.corvetteforum.com/c3-t...aft-angle.html
Old Feb 9, 2014 | 04:13 AM
Garys 68's Avatar
Garys 68
You just failed the test. Get used to your fillings rattling out of your mouth.
Forget the driveshaft angle, that will be within spec. You need to match the motor and differential angle.
To Driveline angle?
