What does this (broken) part do?
Old Feb 8, 2014 | 09:43 PM
biscuitville's Avatar
biscuitville
Default What does this (broken) part do?
Snapped this part in two while messing with my headlights. Hopefully superglue will hold it. Will someone please tell me what this button does? I've never pressed it. It is #8 in the pic below.
Btw - replaced the headlamps with Wagner halogens H5001 and H5006. They were fairly inexpensive and seem to be much brighter.
Thanks,
AL
[IMG][/IMG]
Old Feb 8, 2014 | 09:49 PM
'75's Avatar
'75
Turns on the warning light in the dash for the headlights. Indicates when they are fully up.
http://willcoxcorvette.com/product_i...ducts_id=24163
Old Feb 8, 2014 | 09:51 PM
diehrd's Avatar
diehrd
I think that will open the head lights when the normal switch wont like a bypass .. others will know for sure DUB will know
Old Feb 8, 2014 | 09:54 PM
gcusmano74's Avatar
gcusmano74
Old Feb 8, 2014 | 10:00 PM
biscuitville
Thanks everyone.
Old Feb 8, 2014 | 10:19 PM
CanadaGrant's Avatar
CanadaGrant
New one is about 30 bucks. If you tighten it, it will crack like the one you have. When you turn the wrench on the new one, remember, it's plastic...
Old Feb 9, 2014 | 08:04 AM
Alan 71's Avatar
Alan 71
Hi Al,
I believe the switch turns the headlight warning light in the center gauge bezel off when the headlights are completely up.
The tab on the 'link', (item 15), pushes the button in to turn the warning light off. The dash light comes on as soon as you pull the headlight switch and stays on until the button is pushed in.
The switch often get broken because if you reach through the grill to push the lights up or down by hand it's the easiest thing to grab and then…
Regards,
Alan
To What does this (broken) part do?
