I think I picked the worst project to start on with my '76. So far it's not been as strait forwarded as I'd hoped. We just got this car and I noticed that emergency break doesn't work so I thought that would be a good first project. I get rear right tire off and there is no rivets or emergency brake. the wire was cut off and the whole brake was missing. No problem, I bought a kit to just redo both of the back emergency break.
So now my problem...I'm trying to take off the other side rotor and even though I've drilled the rivets out, it won't budge. It's on there as tight as it was before I took the rivets out. Any suggestions on how to get it out? I've pounded a little on the inside of the rotor (probably a bad idea) but nothing works. What am I missing and how aggressive can I get with it? Thanks!
Sometimes they can be quite tight. After drilling out the rivets completely, I gave mine a couple good hard whacks with a 5 lb. hammer......popped right off. Don't be afraid to get aggressive.
Soak the center hub area with your favorite penetrating solvent. Let it set for an hour or so and then get busy with a good size hammer between the studs.
Just got done with my brakes, they just aint fun. My left rear was froze from a caliper leak, I took a punch and jus broke the internals the rotor jus fell off. I had a guy I work with put them back together ( I don't have much patience at times). We used stainless where we could, I got got my parts from the local Vette guru. He did not recommend stainless spring he said there to stiff to work with.
Thank you all for the advice. I've made sure that the star wheel is very compressed all the way and I've soaked it with WD-40. I spend about 10 minutes just pounding on it but no luck yet. I'm going to let it sit over night and hopefully that WD-40 will loosen it up. Wow what pain!
WD-40 is not the best stuff for the job. It kind of sets on the surface. Get something like PB Blaster or Kroil. My personal favorite is Hoppe's #9 Gun Solvent.
The WD stands for Water Displacement. It is not a penetrating oil. If WD-40 gets it off then it wasn't that rusty in the first place.
Penetrating oil on the hub and around the lug nuts, heat. There is also a freezing spray you could try. You might be able to get a puller into the 2 holes for the parking brake adjustment. BFH.
Hey, thank you all for the advice... I'm learning! I'll be sure to get the right kind of penetrating oil next time. It seems the WD-40 worked. The morning I gave it a few good whacks and it came off...FINALLY... Now the hard work begins!
I am about to start the same project on parking brakes... What are the riviets you speak of drilling out?
If you have to ask that question I suggest you take your car to a Corvette shop. Plus, it can be a very frustrating procedure even if you mechanically inclined.
The rotors are riveted to the stub axle from the factory to match parts to get the correct run-out on the rotor face. These have to be drilled out to remove them. Make sure to mark the position for reassembly, and do a search to learn all you can about Corvette brakes. They need to be done correctly to achieve max performance and a good solid pedal.
Hey, You gotta start somewhere... Look at the picture I posted above and you'll see 5 counter sunk holes. They might have rivets in which case you'll use a 1/4 bit to drill into them about 3/4 inch. After that use a chisel to pop the heads off and then you can push the rest of the rivets inward. Good luck, it's a pain in the butt. In my case anyway.
Sorry Mijohnst, I am not trying to hyjack your thread here, but I am trying to learn. Thanks for the replies. Thegazman, I apprecate your concern. Mine is a project car and not a daily driver. I am not so proud to seek out a professional if not completely confident. Just trying to learn... Thanks guys...
Oh, don't be sorry. I'm new here too. It's nice to come to a place where there are so many experts. I think they understand us noobies and I'm glad they take the time to share their advice.
