What amp alternator?
Old Feb 11, 2014 | 09:46 AM
Franks73's Avatar
Franks73
Default What amp alternator?
I want to replace the alternator on my 73. It will be a carb fed 383 stroker, with Vintage AC. The choices I see are 70-85-and 140 amp. Is there a risk going with the 140 amp? I am replacing the rear wire harness, and the engine harness. Thanks for your time and experience.
Old Feb 11, 2014 | 09:55 AM
gkull's Avatar
gkull
The problem with 140's is the shear size. If you have taller valve covers for RR's
I use the powermaster 105 amp single wire with the bigger pulley to not exceed 17,000 rpm.
thegazman's Avatar
thegazman
Default thegazman
I went with a CS144, 140 amp in my 79. The one feature I like about the CS is that it puts out good amps at idle to handle my amp and electric fans.
Old Feb 11, 2014 | 09:59 AM
thegazman's Avatar
thegazman
Default thegazman
I didn't know that. Learn something new everyday. My CS144 is the same size as the original 60 amp.
Old Feb 11, 2014 | 10:22 AM
Mike Ward's Avatar
Mike Ward
Your car came with a 61 amp unit. Unless you've added more electrical accessories, what purpose would a bigger unit serve?
Old Feb 11, 2014 | 11:25 AM
thegazman's Avatar
thegazman
Using Mike's rational: Your Vette came with a 190HP V8, why are you updating to a 383 stroker? The 190HP would surely get you to the grocery store.
Old Feb 11, 2014 | 11:46 AM
Mike Ward's Avatar
Mike Ward
The 383 ostensibly produces more power allowing the car to go faster, if that's what the OP wants. What purpose would putting a bigger alternator serve?
I just love how the word 'updating' gets thrown around as an excuse to make illogical decisions.
Old Feb 11, 2014 | 12:26 PM
BKbroiler's Avatar
BKbroiler
That's what I was going to say. Larger alternator capacity, high flow water pump, high pressure oil pump - it all takes power to run. If you're concerned about the power getting to the rear wheels these aren't necessarily good choices.
Old Feb 11, 2014 | 02:49 PM
thegazman's Avatar
thegazman
Default thegazman
Mike.... You are absolutely correct; a newer, more efficient, alternator would serve no purpose. I just love how you are always logical and everyone else is illogical.
Old Feb 11, 2014 | 03:38 PM
Mike Ward's Avatar
Mike Ward
Newer, more efficient?
Please pull the other one.
Old Feb 11, 2014 | 05:35 PM
jb78L-82's Avatar
jb78L-82
Wow as usual always fun!
I'll give you a few reasons why an "updated" CS-144 alternator is a better choice than the 63 amp 12SI even if you do not have very high amp loads outside of the stock amperage draw overall :
1. The CS-144 will provide MUCH higher amps at low RPMS like at idle unlike a stock 12SI especially for later cars with A/C and rear electric defroster.
2. The CS-144 will run much cooler than a stock 12 SI and will last longer as a result
3. The CS-144 will be taxed MUCH less at higher amperage draws and will last longer as result.
4. The CS-144 will charge the battery MUCH quicker under higher loads.
5. If the car has any type of high amp draws beyond stock, the CS-144 will easily handle the load.
On my 78, I have Hella Euro Halogens (4)-55/60 watt low and 100 watt highs- and the stock 63 amp and 100 amp 12SI''s I had could not charge the battery with the lights on at idle.
Hope that helps!
Old Feb 11, 2014 | 06:30 PM
mrvette's Avatar
mrvette
Hope that helps!
Yeh, pretty close as to why a CS144 is on the motor home, charging TWO batteries, and all that crap dragging a fridge on a power inverter, and a/c, etc.....running down the road....
then we get into the problems of on my vette, electric fans, properly wired off the alt, and NOT the battery,.....IF anyone understand electricals, you know that a ~100 amp alternator is a help to the car electricals.....
Old Feb 11, 2014 | 06:40 PM
Mike Ward's Avatar
Mike Ward
Hope that helps!
All potentially true- but not applicable to the OP's car.
He makes no mention of any non-stock accessories or add-ons. So again, what is a bigger alternator going to give him?
Old Feb 11, 2014 | 06:49 PM
mrvette's Avatar
mrvette
Electrical 'room' to expand......
Old Feb 11, 2014 | 07:08 PM
hugie82's Avatar
hugie82
dbelectrical.com/
I've used these guys before with excellent customer service and they are very fast with shipping! Check them out, they have an alternator for any need!
Old Feb 11, 2014 | 07:13 PM
Jasonb86's Avatar
Jasonb86
The OP mentioned he has Vintage AC in his car. I have the CS144 alternator in mine along with vintage AC and Dewitt SPAL fans. I like it and it was an easy installation.
Old Feb 11, 2014 | 07:30 PM
jb78L-82's Avatar
jb78L-82
OP's car.
I guess you missed reasons 1-4?
Here is another reason: For the small difference to buy a new cs-144 with 2.5 more amp capacity, much more efficient etc versus the outdated 12SI, its a no brainer! There is a reason the 12si was discontinued and its not because the newer alternators were no better than the old.
To What amp alternator?
Old Feb 11, 2014 | 08:10 PM
lionelhutz's Avatar
lionelhutz
Installing a higher current alternator means you need to upgrade the charging wiring. If you're not needing the higher current capability then why go to the effort? Changing the wiring will also mess-up the ammeter and it won't read correctly either.
Instead of a stupid pissing contest why not ask the OP if he's adding extra load?
Franks73 - are you upgrading or adding anything else electrical to the car and if so, what?
Old Feb 11, 2014 | 09:40 PM
Mike Ward's Avatar
Mike Ward
Not in the least:
The OP has a '73. There is no rear window defroster like on later cars. The 61 amp alternator is sized to run A/C, even at idle, no flickering lights.
'73 used a 10SI unit. They are renowned for outstanding reliability and durability. Cooling was not an issue on a 10SI. Mine went over 30 years before needing new brushes.
What higher amperage loads? See above comments about durability of the 10SI
Again, what high loads? The stock alternator recharges the battery just fine on mine.
Yes- the 10SI eventually reached it's output amperage capabilities at 63 amps. The 12Si reached it's limit at almost double that. The CS series doubles the output yet once again.
More reliable, no. More efficient, no.
Old Feb 12, 2014 | 08:04 AM
jb78L-82's Avatar
jb78L-82
i had a 10SI on a 73 Nova SS when i owned the car from 78-90. I went through at least 4 alternators in 12 years and 140,000 miles. Reliable No. it's foolish to state that the 10/12SI alternators are just as reliable as the later CS130/CS144 and plain misleading. Do some research on this issue and this fact will be evident. are the 10/12 SI alternators decent units? Yes. Are they just as good as later models? NO!
