Steering Box Lube
Old Jul 14, 2002 | 11:58 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Default Steering Box Lube
What type of lube do you use in the steering box? How do you get it in the box? Thanks Chuck
Old Jul 14, 2002 | 12:26 PM
Paul L's Avatar
Paul L
Default Re: Steering Box Lube (chucks)
I removed the bolt at the upper right and filled until I could see the grease at the bolt hole at the upper left. Filled with a plastic squeeze tube (e.g. PolyFill) with the flat bottom end cut off. And cleaned the tube beforehand of course. What did I use? I may get into deep doo-doo here with members because I know there is a special GM lube for this purpose. But it was not in stock. So someone here suggested ordinary chassis lube with some Mobil 1 added. I mixed up a thick slurry; about one to four, oil to grease and squeezed it in the top hole. Seems fine: no problems so far. But I would certainly listen to others' opinions before you do the job.
Old Jul 14, 2002 | 06:38 PM
chucks's Avatar
chucks
Oldtimer
Default Re: Steering Box Lube (paul79)
Thanks Paul. I will try to see if my dealer has the GM grease if not i will try your mixture. Thanks Chuck
Old Jul 15, 2002 | 01:36 AM
LT1driver's Avatar
LT1driver
in 67 manuals called for chassis grease, in 70 called for "special" gear lube from GM, same box just different philosophy I think, used chassis grease in all cars I have owned over years with not problems. :D :cheers:
To Steering Box Lube
