Pulsating vibration.
Old Feb 15, 2014 | 06:50 PM
gjohnson's Avatar
gjohnson
Default Pulsating vibration.
Hoping someone knows whats up.I narrowed it down to the transmission.At about 50 mph and up I get a pulsating vibration that shouldn't be there.Pop it in neutral and its smooth sailing.Trans is not leaking anywhere,yet.Its a TH350 that has about 2000 mi since rebuild Whats up? Thanks
Old Feb 16, 2014 | 10:16 AM
wombvette's Avatar
wombvette
What kind of exhaust? Often a harmonic occurs especially with hard welded custom exhaust.
Also make sure there is not too much negative camber at the rear wheels.
But indications are that it might be a balance problem since it stops with engine at low RPM.
Old Feb 16, 2014 | 06:05 PM
Jig A Low's Avatar
Jig A Low
I had the same issue in a '70 T/A, 350/350---it turned out to be the bolts on the torque converter had came loose a bit.
Old Feb 16, 2014 | 10:01 PM
soarguy77's Avatar
soarguy77
3rd Gear
I had a similar issue with my 77 350 a couple of years ago and it turned out that the drive shaft had a little dent in it.
Old Feb 18, 2014 | 02:33 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
It could also be a bad U joint, they can cause vibrations when they fail/are failing.
Will
Old Feb 18, 2014 | 07:42 PM
gjohnson's Avatar
gjohnson
Thanks for the replys. I looked at the driveshafts and the right halfshaft has a ding in it.That surely puts it outta balance I'm going to replace it and go from there.
Old Feb 18, 2014 | 07:48 PM
cagotzmann's Avatar
cagotzmann
Does the vibration have a cycle. eg vibrates for 1 sec stops for 1 sec. or is it a constant vibration @ 50MPH ?
Old Feb 18, 2014 | 07:50 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Default Ding
[QUOTE=gjohnson;1586206629]Thanks for the replys. I looked at the driveshafts and the right halfshaft has a ding in it.That surely puts it outta balance I'm going to replace it and go from there.[/QUOTE
Not sure how a ding would cause an out of balance condition; the material is still there??
Old Feb 18, 2014 | 10:07 PM
Gale Banks 80''s Avatar
Gale Banks 80'
I'm not so sure that a ding would throw it out of balance, I'm not so sure they were really balanced in the 1st place, since they turn at a somewhat slow RPM. However if the ding is enough that the Shaft is bent, that could do it.
Old Feb 19, 2014 | 09:12 AM
jnb5101's Avatar
jnb5101
everything aft of the trans correlates to road speed, forward is engine speed. the vibration starts at 50 mph (about 2000 rpm). run the car in first or second gear at 2000 rpm and try to duplicate the problem. that will help determine from where the problem originates.
Old Feb 19, 2014 | 10:21 AM
cv67's Avatar
cv67
St. Jude Donor '05
Just at crusing speed , under load or under decel also?
How old are your wheels and tires?
No leaks from pinion seal?
Ck a few more things out first before buying anything
Old Feb 19, 2014 | 12:54 PM
TedH's Avatar
TedH
I get similar drone at 50+. I've attributed it to my 12-year old super turbos and custom welded exhaust. It declines when I let off the gas exiting the highway.
Old Feb 19, 2014 | 06:11 PM
hugie82's Avatar
hugie82
Pinion bush will vibrate with wheel speed trans or torque converter will follow engine speed.
Old Feb 19, 2014 | 11:18 PM
gjohnson's Avatar
gjohnson
Pinion is leaking a little and its a pulsating vibration ,like 1 sec. on 1 sec off.
Old Feb 20, 2014 | 12:13 AM
cagotzmann's Avatar
cagotzmann
I have the same problem on my 1978. Here are my symptoms.
Car in netural or park. Rev the engine to about 1800-2000 RPM I get a vibration. When I disconnected the torque converter I could not feel a vibration. Now my stock torque converter is about 1700-2000 Stall. I have not replaced the torque converter yet but I feel it has something to do with the problem. I dont notice the problem in 1st or second gear because the engine RPM vs speed of the car doesn't seem to be noticable, only in 3rd gear. Now when I drop from 3rd to netural I dont notice it, but this is because the RPM of the engine drops below the stall of the torque converter and disengauges. Did your torque converter get replaced when you rebuilt the transmission ?
Old Feb 20, 2014 | 10:02 PM
Will's'74VetteL-82
When I got my military M1028, it had a pulsating vibration at about 35 mph. The driveshaft had a dent in it, got a new one made with new U joints and no more problems. In the surplus military vehicle world it is common because of forklift damage in the DRMO yards. If the dent is small you could try taking it to a driveshaft shop and have them rebalance it, but they may just want to replace it due to rust and age.
Will
To Pulsating vibration.
