steering bracket needed?
Old Feb 16, 2014 | 11:35 AM
Sweat's Avatar
Sweat
Default steering bracket needed?
When installing new headers on my '81, I removed this bracket on the the driver's side firewall for clearance. I am curious if it wouldn't hurt if I just left it off.
After reading Jim Shea's article, it seems it was only used for models 1969-1976 for a cable of the transmission interlock system. He says 1977-1982 started using a 'finger inhibitor' on the ignition lock cylinder.
http://jimshea.corvettefaq.com/wp-co...tems27JL04.doc
Other forum members with late C3's also mention having this bracket with nothing connected to it. Makes me wonder why Chevy continued to leave it on. Is it useful at all for late model C3's?
http://i79.photobucket.com/albums/j1...1329193194.jpg
Old Feb 16, 2014 | 06:39 PM
DUB's Avatar
DUB
I would not leave it off. Cut the material you need for clearance...but re-install the plate. It strengthens the base of your steering column to your firewall. Just my opinion.
The reason being...GM had already paid to have the tooling and dies made to make this part...so why spend money to modify this plate if simply not installing the cable is the only difference due to the steering columns had changed and did not have that arm coming out of the side as previous years.
Hope it all goes well.
DUB
Old Feb 16, 2014 | 09:18 PM
drwet's Avatar
drwet
The bracket mounts the steering column to the firewall so you need to have it. The part I think you are referring to on the lower right (left of the picture) that is interfering with you headers can be cut off if it is not used on you car. I honestly don't know what it is for, but it must have been used for something on one of the Corvette models. On my '79 it never had anything in it.
Old Feb 17, 2014 | 06:09 PM
DUB's Avatar
DUB
His initial post tells what the hole in the bracket is used for....which was removed in later years due to steering column designed changed.
DUB
Old Feb 17, 2014 | 10:15 PM
Sweat's Avatar
Sweat
The bracket is not actually connected to the steering column. It is only attached to the engine-side firewall around the column.
I am guessing that since it still exists but no longer has a cable attached beginning 1977, it may also be necessary for the fiberglass firewall reinforcement around the steering column. So, perhaps the protruding lip (that once held a cable attachment) could be cut off, but the bracket itself may be providing support for the firewall.
I found it easier to R&R the bracket nuts from the inside. Headers cleared perfectly.
https://www.dropbox.com/s/udazbsc04l...%20bracket.jpg
Old Feb 18, 2014 | 06:01 PM
DUB's Avatar
DUB
Sweat.
Yes...I know of this bracket very well...and it is possible to trim off that extension area for the cable....and it should not weaken its integrity enough to make is a concern....so you have the clearance you need.
Yes... the two flange nuts are accessed from the inside and one of the threaded studs is staked permanently to the bracket...and the other bolt is a carriage bolt.
DUB
To steering bracket needed?
