Those photos are for the 65-67 exhaust...not the 69....the 65-67 was straight through.....the 69 is wider and flat...which leads me to believe it had two chambers in it.....
Hi Jebby,
I agree that the 69 pipes are quite different than the mid-year pipes…. (which are wonderful too).
I believe it's the size of those 2 tubes and the 'reverse flow' (whatever that actually means in this case) that makes the side exhaust somewhat restrictive….. but OH what a sound.
Regards,
Alan
It is a wonderful sound....my father had them on every shark he had...(about 6 or 7)
I am going to go the Sweet Thunder route....the 427 has to breathe a bit....if it is too loud...I'll figure something out....but it can't be any louder than my 66' was.....
i have the sweet thunder 2.5" units on mine. they are a bit loud and i like em. i had one woman at a car show walked up and said that car sounds wicked. my x wife complained about the mufflers in the side pipes in another vette i had, so i took them out and she never rode with me again. problem solved
Like the description.....does anyone know what these look like inside the chamber?
It appears from the outside that it is a 2 chamber muffler....
Pics?
Jebby
Shoot me a reminder PM This weekend I'll take a look in my original sidepipes with my borescope camera and we'll get to the bottom of this.
BTW I have a set of SB and BB sidepipes so I'll look in both
so do you have the C2 style mufflers? I only see 2.25'' listed for '69 style mufflers.
The C-3 long oval sidepipe mufflers were two tube cross-flow mufflers. the problem is they had very small flow tubes, so they were restrictive. Both flow tubes were staggered inside & they overlapped each other & cross-bled basically. To answer another question, I KNOW that a 3" OD straight muffler will fit under the OE style sidepipe covers on a C-3, but a 3.5" will NOT.
