tach drive ?
Old Jul 14, 2002 | 06:30 PM
danzig74c's Avatar
danzig74c
Default tach drive ?
i need to know is this the tach drive connection ?
its on a 1974 350 4speed convertible :D
Old Jul 14, 2002 | 07:10 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Default Re: tach drive ? (danzig74c)
Looking at the photo and I'd say there isn't a tach drive connection on it.
The tach drive connector looks just like a speedometer connection (actually, it basically IS a speedometer connetor) as is located opposite the vacumm advance under the base plate. Simplier put, the tach drive connection would be about 90 degrees to the right of your arrow and is about as big around as a nickel.
Question, this is off a 74, did the 74's have a mechanical tach or was it electric. My 73 is mechanical, not sure what year they converted to electic.
Old Jul 14, 2002 | 08:12 PM
Alwyn678's Avatar
Alwyn678
Default Re: tach drive ? (gb4622)
[/QUOTE]
Yes the last mechanical tach drive was in 74.........:LOOKS like you are missing the adapter where the cable screws in
[Modified by Alwyn678, 7:14 PM 7/14/2002]
Old Jul 15, 2002 | 12:31 AM
jrh74cp's Avatar
jrh74cp
74 has a tach drive. 75 went HEI and the electronic tach came about.
Old Jul 15, 2002 | 08:22 AM
danzig74c's Avatar
danzig74c
Default Re: tach drive ? (jrh74cp)
i see i could better buy a new tach meter electronic i geuss....
Old Jul 15, 2002 | 01:30 PM
Twin_Turbo's Avatar
Twin_Turbo
See Dennis, I told you so :D
I'd get a new one if I were you, this one looks pretty hosed :( (or a good used one). They are pretty expenisve though. Or you could get an electronic tach and distributer, might be more economic and definetely more reliable in the long run
Old Jul 15, 2002 | 07:57 PM
danzig74c's Avatar
danzig74c
Default Re: tach drive ? (Twinnie)
euh.... and my new mallory unit ? :rolleyes: :( :D
Old Jul 15, 2002 | 09:30 PM
Juliet's Avatar
Juliet
On my '70 the tach cable goes on the other side from the vac canister thinggie. ie, the vac connector is on the pass side, the tach hookup is on the driver side. I don't know if they changed by the time yours was built though.... ~Juliet
Old Jul 15, 2002 | 09:49 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Dennis, that doesn't look like my tach drive distributor. If you need a tach drive distributor check with Lars and see if he might have one. Another possibility is to check EBay, usually there are a few Corvette tach drive distributors for sale there. It will probably be in rough shape, but Lars or Tom454 can do a good job rebuilding it for you. I rebuilt my own with parts from Zip and Lars for less than $100.00. It is as good as new.
Old Jul 15, 2002 | 11:06 PM
jdunne's Avatar
jdunne
There are a number of brands of distributor avail that let you keep the mech tach drive but give you electronic ignition....this is so that you can keep your stock tacho in the dash......if you dont mind swapping the tach guage for a later electronic one then you can use a later model distributor w/o the mechanical drive.....74 was last year for mech drive tach...john :chevy
Old Jul 16, 2002 | 10:42 AM
Twin_Turbo's Avatar
Twin_Turbo
Uhm, sell it! :)
I didn't know your distributor was THAT hosed until I saw it last Sunday.
Try to get a used one first and it all else fails it's electronic time. I don't have a vac. advance distributor anymore (except for the malloy one I need for my own engine) I only have el. HEI ones.
Let me look around for you what I can find (cheap)
Marck
To tach drive ?
