Cowl Induction on '74 Vette
Old Feb 20, 2014 | 01:11 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by paul 74
I get constant cowl fresh air by leaving the electric induction unit in the basement.
Your car runs with no intake manifold? D*mn that is magic!
The big 'fail' with the stock system is that there's two large intake snorkels that are left wide open at all times. These are unfortunately positioned to suck in all sorts of hot air from the engine compartment.
As tested several years ago on my own car, actual temperature drop inside the air cleaner housing at 100 mph is a whopping 1-2*F depending on wind direction.
Old Feb 20, 2014 | 01:16 PM
Big Block Dave's Avatar
Big Block Dave
I get constant cowl fresh air by leaving the electric induction unit in the basement....
I did the same thing, except mine might be in the attic. Im sure it does "something", but realistically I think it largely acts as a sound deadener for engine noise, except for full throttle conditions. With it removed, there certainly is alot more engine "sound" into the cockpit.
I'd rather let the hot air out of the cowl, than let the induction mechanism dictate when cold air is "allowed in".
Old Feb 20, 2014 | 01:58 PM
Kid Vette's Avatar
Kid Vette
Originally Posted by Mike Ward
It amazes me how gullible the peanut gallery is. Somebody with a desk dyno please calculate how much HP it takes to reduce a car's ET by 1 second in the 1/4 mile.
Now, given the rule of thumb that it takes a decrease of 11*F intake air temp to increase engine HP by 1%, figure out how much the intake temp would have to decrease to achieve this HP gain.
Finally- cowl induction systems don't really do much below 100 mph. They do nothing at a stand still, like at the start of a 1/4 mile. Any gains would come just as the car is approaching the 1320 mark, not much before.
A quick calc indicates that intake temps would have to be below absolute zero to achieve the supposed 1 second decrease in ET.
But the argument will go on 'cause Duntov told the press'.
Actually Zora said it would take a second off 0-60 times not the1/4 mile as you're discussing.
But now that you're on a roll, would you care to weigh in on the function of the C-clips on the stub axles? :-)
Old Feb 20, 2014 | 03:37 PM
Mike Ward's Avatar
Mike Ward
0-60? Even worse. He must have had his fingers crossed behind his back. Wonder how he kept a straight face.
I saw a comment about replacing c-clips and side yokes the other day 'for safety'.
Old Feb 20, 2014 | 03:53 PM
Paul L's Avatar
Paul L
For most us the cowl induction really makes little or no difference in driving. I do agree it may let some hot air out.
Old Feb 20, 2014 | 04:07 PM
Mike Ward's Avatar
Mike Ward
I don't follow- how does it let hot air out?
Old Feb 20, 2014 | 04:49 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Yeah,..all those stupid cowl hoods I saw at the drags last weekend,..some 6" tall, I'm sure are just "for show". And fresh, cool air to the carburetor,..what a stupid idea!
Old Feb 20, 2014 | 05:23 PM
Paul L's Avatar
Paul L
I'll eat humble pie on this one. My thought was that heat would flow from the front of the engine back and out through the cowl vent (with induction unit removed). But even with the unit removed the passage to the cowl vent is still sealed off by the rubber ring on the air cleaner to hood interface. So while air can be sucked into the carb - and I can certainly hear it - venting in the other direction is not really possible with the rear hood seal blocking off the cowl vent. So I fouled up. My apology to you and other readers! Heck, I just drive my car. I don't have ribbons on it.
Excuse? Well not really. Been doing my income tax today...paid out a 1974 convertible equivalent last year. Love these taxes in Canada.
Old Feb 20, 2014 | 07:25 PM
Mike Ward's Avatar
Mike Ward
I'm not saying or thinking that the concept is wrong. There's no real reason why air from the engine compartment couldn't enter the air filter housing through the snorkels and flow backwards through the cowl induction duct into the windshield plenum if the flapper is removed.
Hmmmmmm.
Old Feb 20, 2014 | 08:05 PM
Paul L's Avatar
Paul L
Hmmmmmm.
I am sure some flow does occur but I doubt it is substantial. These threads make me wonder why I even bother with such things when my car runs 180*F on the highway at 70mph (112kph). I just like the intrigue.
Old Feb 20, 2014 | 09:34 PM
7t9l82's Avatar
7t9l82
a second is idiotic.
Old Feb 22, 2014 | 07:13 AM
Big Block Dave
To the best of my recollection [since Im not in my garage right now], with the flapper removed, there is a fairly large area that is left wide open under the hood, immediately behind that air cleaner ring area on the hood, that is not sealed off by the air cleaner, so there really is no reason why it shouldnt act as a vent.
Edit: I looked back at your picture of the actual flapper assembly. It seems that you replaced the plastic support under the hood...I believe I left that piece off.
