Cowl Induction on '74 Vette
Old Feb 18, 2014 | 07:08 PM
ClassicG's Avatar
ClassicG
Default Cowl Induction on '74 Vette
Hi, I have a '74 L82 that has the cowl induction - I'm not sure if they all had it or not. I don't think mine is working - but how would I know? Is there a way to test it? I see a brown and black wire going to the hood. I had heard once that there was a vacuum actuator somewhere. Thanks.
Old Feb 18, 2014 | 07:38 PM
gcusmano74's Avatar
gcusmano74
There is an electrical switch on the gas pedal linkage. When your foot is nearly to the floor, the switch closes and actuates the solonoid that opens the cowl induction air flap.
To test it, turn the ignition key to "run". DON'T START THE ENGINE YET. Fully depress the gas pedal.
You should hear the solonoid operate.
If you have to do a bunch of troubleshooting, disconnect the throttle cable from the carb, or you will flood the engine.
Also, you will notice that while driving at WOT, the induction noise will increase considerably. With stock mufflers, the induction noise can often be louder than the exhaust.
Old Feb 18, 2014 | 08:07 PM
ClassicG's Avatar
ClassicG
Thanks, that seems like a straight forward test. Does the actuator require vacuum - and if so, I assume it gets the vacuum (when engine is off) from the vacuum canister? As for noise, the engine compartment is very quiet while driving so it makes me think its closed currently. I've never WOT it yet, so maybe mine works. I'll test it this weekend.
Old Feb 18, 2014 | 08:18 PM
Paul L's Avatar
Paul L
This advice is correct. I just removed the motor ***'y and have cowl induction all the time. It was a funky gimmick at the time. Not of much use.
Old Feb 18, 2014 | 09:06 PM
Mike Ward's Avatar
Mike Ward
and as demonstrated is 'all show' and 'no go' anyway.
The system is electrical, no vacuum involved.
Old Feb 19, 2014 | 07:01 AM
aussiejohn's Avatar
aussiejohn
Default Mike's right.
The only purpose it serves is to "intimidate" the person you're lining up against. At the drag strip, of course. And provided they can hear it above the exhaust of both cars revving up.
Regards from Down Under.
aussiejohn
Old Feb 19, 2014 | 10:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ClassicG
...I'm not sure if they all had it or not...
All had it.
Old Feb 19, 2014 | 07:22 PM
Paul L's Avatar
Paul L
In the absence of the electrical motor and flap it sure sucks a lot of air even at idle. My Wife has commented "What is that noise?". My answer "A Corvette V8 breathing". She is OK with that.
Old Feb 19, 2014 | 10:41 PM
Kid Vette's Avatar
Kid Vette
Zora Duntov,"compared to a non-ducted hood, it (the new for '73 ducted hood) cuts 0-60 mph times by a full second in the standard engine Corvette."
Mike Ward. "'all show' and 'no go'"
Who you going to believe?
Old Feb 20, 2014 | 12:26 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Most would disagree that a cowl induction system is "all show and no go".
Every 11 degree reduction in induction air temperature will equate to a 1% HP increase. Underhood temps get pretty warm, especially in a Vette.
Also, some Chevy engineers named Roe, Piggins, and Shinoda designed the cowl hood induction system, first designed for SCCA and Nascar racing. Would GM put three of their top engineers to work on an "all show and no go" project?
More here:
http://www.camaro-untoldsecrets.com/...es/rpo_zl2.htm
and here,..
http://books.google.com/books?id=1sS...20test&f=false
Lastly, if you own a 73-75 Vette with a working cowl induction system, cut 5-6 pieces of yarn or string in 6" lengths and tape them to the back of the hood. Then take her for a "spirited" drive. You'll quickly be convinced the system works as the string is forced toward the engine's induction system.
FWIW
Old Feb 20, 2014 | 01:26 AM
Mike Ward's Avatar
Mike Ward
Not again..................
Old Feb 20, 2014 | 01:38 AM
tfi racing's Avatar
tfi racing
Yep, a world of difference on my 165 horse L48, once I got that flap optimized and tuned right, it sure did terrorize that hockey mom and her lil'ones quivering in their 1984 minivan last week...then again maybe it was the howl of the studded retreads...
Old Feb 20, 2014 | 09:05 AM
Mike Ward's Avatar
Mike Ward
It amazes me how gullible the peanut gallery is. Somebody with a desk dyno please calculate how much HP it takes to reduce a car's ET by 1 second in the 1/4 mile.
Now, given the rule of thumb that it takes a decrease of 11*F intake air temp to increase engine HP by 1%, figure out how much the intake temp would have to decrease to achieve this HP gain.
Finally- cowl induction systems don't really do much below 100 mph. They do nothing at a stand still, like at the start of a 1/4 mile. Any gains would come just as the car is approaching the 1320 mark, not much before.
A quick calc indicates that intake temps would have to be below absolute zero to achieve the supposed 1 second decrease in ET.
But the argument will go on 'cause Duntov told the press'.
Old Feb 20, 2014 | 09:15 AM
Kid Vette's Avatar
Kid Vette
Just like throwing some red meat at a starving lion. I knew you couldn't resist.
Old Feb 20, 2014 | 09:17 AM
Ontario73's Avatar
Ontario73
Mike, next you're going to tell us that chrome valve covers dont add the 5hp as advertised!
Old Feb 20, 2014 | 09:33 AM
Mike Ward's Avatar
Mike Ward
5HP each you mean.
Old Feb 20, 2014 | 11:08 AM
billla's Avatar
billla
St. Jude Donor '14
The most hilarious aspect of the "I make more power - I did the math!" brigade is that most of them a) make < 1.2 HP/CID, b) have likely never seen the far side of 80 MPH, no less 10/10ths on a road course or dragstrip and c) never bother validating their claims (because why should they?) on a chassis dyno or on the track.
Racing <> street.
I'm waiting for Mr. Two Inch Tube to weigh in here...
To Cowl Induction on '74 Vette
Old Feb 20, 2014 | 11:19 AM
billla's Avatar
billla
St. Jude Donor '14
5HP each you mean.
10 if it's got a K&N breather in each one.
"For every .00005 PSI reduction in crankcase pressure, 10 HP is gained" - Abraham Lincoln
Old Feb 20, 2014 | 11:41 AM
Paul L's Avatar
Paul L
I get constant cowl fresh air by leaving the electric induction unit in the basement.
Old Feb 20, 2014 | 12:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
