Hey g-Cool. You still gonaa build me an aluminum sbc block 427 some day, right. My ex-wife just took all my money, so no hurry. But someday.
Bee Jay
Sorry to hear that. I just went through the same thing. Tough getting started back on the car when I had to buy half of it that she never put a nickel into. Oh well
Oh no, I'm still with my second bride of 13 years. The first wife, the one that left 19 years ago, went broke and got a $500 an hour lawyer in Santa Barbara. Till death do us part. It's different here in Cali.
How you doing Gordon? I see you survived and prolly thrived.
Bee Jay
Just put it on a credit card and then do some overtime later.
As for me and sending the first wife down the river.......... I actually had a lady judge and I was worried. But like the ruling on my home she was very fair. I had put a down and owned a home before I met the wife. So the judge ruled that she was only entitled to 1/2 of the appreciation equity aquired during the 5 years of marriage. She was also responsible for her credit cards and car payments and I got 1/2 the value of all the items aquired while we were married.
Why would the split in duration be uniform, the same split at any given tappet height, throughout the lift range of the tappet when you are dealing with one port that is based on creating a depression so it can function and one port that is dealing with very high pressure at the beginning of tappet rise and quickly bleeds down from there.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You need a custom shaft rocker setup. I tried Jesel but the wait was too long. T&d set me up pretty fast but the first didn't work they were way off. They actually make you a custom set just for your motor no off the shelf stuff.
I finally got the correct set, you use shims to get them perfect on the valve, I have have not had a problem with them, and I take a look twice a year and I haven't had to make any lash adjustments in three years now.
Once you go to shaft rockers you will never go back, sure they are expensive but once you get a set a set you will see what I am talking about and you need a custom set up anyway with those headers and the shaft rockers make both intake an exhaust pushrods perfectly vertical.
I have revved mine up to 8,000 RPM and it took it even though I am not making any more than 7,000RPM. buy nothing from Eagle and constrain yourself from making max HP as you want to be able criuse around town. I could have made more HP but I wanted a engine that was "streetable"
Ill second that motorhead. Keep "listening" for maybe one that would go out of wack and with shaft rockers they just dont.
No stud deflection either with larger cams gets a little scary way things move around so much. Cant be good for anything.
Sucks paying for them but only have to buy them once
I wonder guys if we were to all move forward perhaps another 10 years plus (and presuming the internal combustion engine as we know it still around and not legislated out of existance) - whether we will all be talking about electronic/hydraulic valve operation. In the same way that current ignition and fuel delivery systems are all ECU based and that the 'mechanical' side of this part of engine control has been engineered out - why not valve operation - i.e throw away the camshaft and instead electronically actuate high pressure hydraulically operated inlet and exhaust valves. Valve springs could also be eliminated by using desmodronic operation. No worries then about overdoing it with valve lift and timing events as it will all be ECU driven. You wouldn't need to even be concerned about valve to piston clearance as sensors could monitor this. You could have totally different 'tunes' for economy cruise and performance in the same way as currently offered aftermarket add-on fuel injection systems.
I'm dreaming a bit fella's
Yes but then it means more expensive diagnostic tools and less things mechanical to play with which for me is half the fun, but then I spent 20 years working on computers and networks so going home and doing that on my car is not what I want to do. Now, well I am a marriage and family Pastor so by the posts previous I might be able to assist someday in my hobby group there too.
They are slightly different. But I have been working on engine similator software for 15 years or so. From the desktop dyno 2000 to the modern expensive programs used today.
The software is just a tool and older less sophisticated software over rewarded big number split duration cams. Like an additional 10-16 degrees on the exhaust side. That did not pan out in real life motors with high flowing exhaust ports.
So when you have high flow exhaust on the heads, free flowing pipes, and high exhaust lifts like .714 gross numbers. The need for an additional 8-12 degrees on the exhaust side is a moot point.
I've noticed on your cams bigger exhaust duration and less lift than the intake. The total flow on an exhaust valve event can be accomplished just as much with shorter duration and higher lift.
I'm not saying that you are wrong. It is just two trains of thought to accomplish the same thing.
To you others.......... T&D is a fellow shop in the area and one of their workers builds his sheet metal intake manifolds at our shop during his off hours
I could have used the same lobe profiles and had the custom cam ground on 104 -108 lobe centers and the valve event numbers advanced to make big numbers and a peaky motor with 30-60 more HP.
But you end up with poor MPG, 1200 rpm idle, choppy race car sound, no vacuum, and need a 5-6 speed closed ratio tranny.
But if you want a higher average broad power curve VS bragging rights just make a happy motor that just does it all. When you get into the mid 600 HP motors it takes a good driver to actually be able to use the power. You have to have the best tires to even stay straight in the first couple of gears. They are even dangerous cars to drive.
Look at the death of our fast and furious drive in a 600 hp Porsche. that is why I have 335 rears and a full roll cage
Thats a pretty good amount of compression for 91 pump gas on a motor with a carb so I'm guessing fuel injection. If so what system are your using?
George lives 5000ft above sea level, for you coastal folks, don't attempt to duplicate this compression at sea level, Your results will not be as successful on 91octane garbage
George why not go with Isky EZ roll lifters? I indoctrinated my buddy into the EZ roll camp now he has been using them in all his USAC 410 sprint car motors. One motor has over 200+ races on a set with no appreciable wear! His shop used to pitch roller lifters after 50 races...Isky Red Zone/Crower HIPPO neither would go much further than the 50 race threshold. Isky/Crower will even rebuild their Red Zone/HIPPO lifters with bushings now. If I were having Larry Torres make me a set of shaft rockers, I would go with steel rocker arms like the Cup boys run
Slightly different....they aren't even close in how they function. One is creating a depression and one is under extreme pressure. The are polar opposites.
Good flowing exhaust doen't need huge splits. Your correct. Based on the I/E ratio of a head you can quickly see if an engine has the wrong cam in it.
Lift means nothing on an exhaust port. Most of the exhaust has escaped at low lift because the exhaust port is under such extreme pressure. As soon as the valve is opened it wants out!! How much time the valve is held open (Duration) is what is important.
I will disagree with you on high lift and short duration. It won't work on a poor flowing exhaust port.
My cams are based on the customers wants and his combination. Some heads require more split than others. Alot of the stock heads from GM on the LS stuff require large splits. Some of of the aftermarket stuff require very narrow splits.
My point is the split between intake and exhaust should never be equal through the lift points because the ports are opposites.
Since when is 256 cfm poor exhaust flow As to I/E ratio. That is another stupid comment. If both of them are massive who cares? David Vizzard, used those generalizations all the time. AFR 245cc heads are not some general SBC low performance head.
Real SBC race heads use 2.25 intake valves and tiny 1.5 inch exhausts.
Because the bore diameter doesn't allow anything bigger. So they have found that big intake cfm is more rewarding than the exhaust side. Yes, and they are lifting the valves to @ 1.00 inches.
