Brakes
Old Feb 22, 2014 | 07:28 PM
Vettes Rule's Avatar
Vettes Rule
Default Brakes
Tomorrow will replace rotors calipers and master cylinder. After reading a lot here, I feel am making a mistake replacing rotors. Just bought car and rust is very bad as brake fluid has been leaking for some time with previous owner. Want to start fresh. Rotors never been turned. 50K original miles. Calipers are SS lined with lip seals.
THOUGHTS PLEASE.
Old Feb 22, 2014 | 07:39 PM
Mooser's Avatar
Mooser
Can't say much about the rotors without seeing them, some flaking in the vents isn't necessarily all that bad, heavy rust / pitting in the surfaces would be a concern, etc. Pics would help.
One thing to remember is that if you change rotors you'll need to check the run-out and possibly (likely) re-shim.
M
Old Feb 22, 2014 | 08:18 PM
Vettes Rule
Here are pix
Old Feb 22, 2014 | 08:54 PM
Vettes Rule
ttt
Old Feb 22, 2014 | 09:39 PM
Mooser's Avatar
Mooser
At the very least they need a real good cleaning and then a proper turning.
Honestly, I'd probably go ahead and install a new set. Relatively cheap and will likely never need to be done again as long as you own the car.
Don't forget to index and mark them and check the run-out
My .02
M
Oh, and I've seen way worse being driven, doesn't mean they should have been but they were, also, those you have could probably be brought back up to snuff but it's not likely worth the effort, most replacements are fairly cheap until you get into some performance sets.
Old Feb 22, 2014 | 09:52 PM
Vettes Rule
My .02
M
Thank you sir
Old Feb 22, 2014 | 10:59 PM
Sayfoo's Avatar
Sayfoo
Wobbly rotors account for most of our problems. If you don't get them right, you will always have problems.
The fronts are easy. Pull the hubs/rotors and get them turned together. Don't remove the rivets unless you have to replace the rotor.
Rears are harder. Either have them machined on the car (I think about $50ea), or you will probably have to use shims if you remove the rotors. The rotor run out correction plates/shims from Rockauto or Napa work well ($15-$18 ea).
Old Feb 22, 2014 | 11:05 PM
noonie's Avatar
noonie
I would just pressure wash the rust out of the fins if you have access to one and then just get cheap organic pads and go. They don't look bad at all.
Old Feb 23, 2014 | 10:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Vettes Rule
...I feel am making a mistake replacing rotors...
Stock rotors seldom need to be replaced. Looks like yours have been off the car in the past. Mic yours. If they are to spec and run out is good, leave them. There are two common misconceptions about these cars: rotors have to be replaced and you have to have an aluminum radiator. Neither is true.
Old Feb 23, 2014 | 11:21 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Lay a straight-edge on the rotor face to see how much wear/grooves are present....maybe having them "turned/re-surfaced" will work....then you won't have poor braking or end up ruing a new set of pads.
My rotors and pads looked like yours....cleaning/sandblasting/rebuilding helps....
Old Feb 23, 2014 | 11:47 AM
Mike Ward's Avatar
Mike Ward
I was expecting far far worse. Do NOT turn or replace them.
Old Feb 23, 2014 | 05:02 PM
Vettes Rule
Oh no. Too late. Only left rear had been off before. I pulled them all. Parking brake assembly was locking up, found spring broken. Plan to rebuild parking brake as well. Only caliper not leaking was on the rotor that had been off.
To Brakes
