jeeze
Old Feb 23, 2014 | 11:44 AM
jb78L-82's Avatar
jb78L-82
Originally Posted by scottyp99
OK, let's not get carried away. Spending other people's money is fun, but it could very easily just be a worn out rag joint, which would cost about 10 bucks and a Saturday afternoon of the OP's time. The main thing here is that you need to find out why the steering is so loose before you can fix it. Fire it up, chock the wheels real good, and have somebody move the steering wheel while you look for where the slop is. Look at the rag joint, steering box, tie rods, ball joints, etc. Front end rebuild kits are not very expensive.
Valve covers are easy to do. If you ask around, there is probably a place nearby that rebuilds starters and alternators, front wheel bearings are pretty easy, but the back ones are a b!tch, you need special tools, and the trailing arm really needs to come off, (which I still have bad dreams about.) It's a big job. The A/C could be something as simple as a pressure switch that is inop, but if it needs a recharge, take it to an A/C guy.
Just pick away at it, and get used to doing that, too. By the time you fix all these things, other problems will surface. It's just the cost of doing business when you are dealing with an old car, but I think it's worth it. You have to decide for yourself if it's worth it to you. Good luck!
Scott
Scott
Borgeson or Steeroids ?? to solve loose steering before diagnosing that the steering components are all good-Not a chance. Fix the basics first before even considering upgrading anything.
Old Feb 23, 2014 | 11:59 AM
qwank's Avatar
qwank
the good thing about the borgeson is you can replace all the tie rods and idler arm first to tighten up the steering, and if you decide to change the box to a borgeson, all your new parts will still work with it
Old Feb 23, 2014 | 02:20 PM
7t9l82's Avatar
7t9l82
i have more specific thoughts on the haynes manual.
Old Feb 23, 2014 | 04:44 PM
briankeery's Avatar
briankeery
Some very good advice you have received here. All in all, it doesn't sound all that bad compared to what some of us started with. Safety first, make it stop and turn, then deal with maintenance issues and finally esthetics.
Old Feb 23, 2014 | 04:49 PM
DBez93's Avatar
DBez93
So today I went out with another Airman, put it up on jacks, and had him wiggle the wheel, the column rotates about 20' each way before the box even moves the arm that attaches it to the rack, with the arm having some play too, all the tie rods etc. Were solid, it's the box... how much does the borgeson cost? Also I have the original maintenance manual that came with the car
Old Feb 23, 2014 | 05:23 PM
scottyp99's Avatar
scottyp99
Are you sure it's the steering box, and not the rag joint? The rag joint is a more likely suspect, and a lot easier fix, so it's worth making sure.
Scott
Old Feb 23, 2014 | 05:52 PM
jb78L-82's Avatar
jb78L-82
If it is the box, consider a custom blue print/rebuild of your oem box, by Gary Ramadei, GTR1999, over on digital corvettes.com for about $300. I had him do mine and it's better than when new! I believe Borgeson system is about $800.
Old Feb 23, 2014 | 07:09 PM
DBez93's Avatar
DBez93
Cool, I guess I'll go join that forum as well
Old Feb 23, 2014 | 07:11 PM
DBez93's Avatar
DBez93
What makes steeroids better than the borgeson system? I have ps, but wouldn't mind deleting it as I've owned cars w/o it before and even liked it more as I could actually FEEL the road through the wheel
Old Feb 23, 2014 | 07:23 PM
DBez93's Avatar
DBez93
Old Feb 23, 2014 | 08:46 PM
DBez93's Avatar
DBez93
@Scottyp99
The column to the box, there is rotational play, I dunno if it would be the rag joint or the box, but I'd like to just fix it instead of tear it apart, replace something, put it back together, and find out I was wrong
Old Feb 24, 2014 | 09:34 AM
scottyp99's Avatar
scottyp99
@Scottyp99
Do you know what a rag joint is? It's in between the steering wheel and the steering box. It's a little flexible joint, sorta like a u-joint...kinda. It gives the steering column the ability to flex just a little bit, because the steering box is ridgidly mounted to the frame, and the body isn't, and can move a bit. the frame can flex a little bit, too. Anyway, if the rag joint is worn, the steering wheel will move before the steering box moves. I don't really understand what you mean in this post, because if the rag joint is bad, and the steering box is fine, and you replace the steering box, you'll still have the play in the steering wheel. In order to "just fix it instead of tear it apart, replace something, put it back together, and find out I was wrong" the first thing you have to do is figure out what is wrong.
Scott
Old Feb 24, 2014 | 10:12 AM
  #33
malicatasr's Avatar
malicatasr
I use the Hayes under a short table leg. Some great advice here. Keep it safe good luck with your new C3.
Old Feb 24, 2014 | 10:52 AM
  #34
Mashman's Avatar
Mashman
Scott
The most likely cause is a worn rag joint, and replacing it is an easy/cheap fix.
Here is a link to a rag joint, so you can see what is being talked about - http://www.ebay.com/itm/69-82-CORVET...#ht_197wt_1145
The worm gear and bearings in a steering box will wear, and cause some slop, but you can adjust that. First make sure that the problem is not the rag joint, or anything else. If the slop is coming from the steering box, you can tighten the lash to remove the slop. Inside the box is a worm gear and bearings, over time they will wear and get loose, tightening the lash screw will tighten them up and remove the slop. On top of the box is slotted screw, and a lock nut. Loosen the lock nut, and tighten the slotted screw - you should only need to go about a 1/4 to 1/2 turn on the screw. If you overtighten it, it's just going to cause the worm gear to wear very fast, and then you will need a new box.
Old Feb 25, 2014 | 01:17 AM
  #35
DBez93's Avatar
DBez93
, thanks guys, I'm not much of a steering/suspension guy, I'm better with engines but I bought this car expecting the opportunity to learn a little bit about everything, I'm just looking for direction with my plan of attack, and a bit of inspiration about my decision
Old Feb 25, 2014 | 05:02 PM
  #36
dlux72's Avatar
dlux72
Originally Posted by doorgunner
Or keep the Haynes handy since it can be a life-saver.......use the pages for blotting up drips on the garage floor.
Finally, someone who knows what do with a Haynes manual!!!
Old Feb 25, 2014 | 05:58 PM
  #37
Snoopysvet's Avatar
Snoopysvet
Also I have about 3 inches of play in the steering wheel of the car, how would I fix that?
Crawl under the car and wiggle stuff
In my case it was the rag joint and Power steering ram, cost my about $100.00
To jeeze
Old Feb 25, 2014 | 06:03 PM
  #38
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Know the feeling but any used car even 10 yrs old will have its appetite for repairs. If you really like the car go for it little at a time, if you arent sure dump it.
Welcome to the hobby!
Old Feb 25, 2014 | 06:23 PM
  #39
7t9l82's Avatar
7t9l82
i used one to light off my charcoal grill.
Old Feb 27, 2014 | 03:29 PM
  #40
dochorsepower's Avatar
dochorsepower
First, about the Haynes manual - use it to replace the Sears catalog in the outhouse!
Then as to your other small fixit's, Just keep in mind that all of them will probably be cheaper than the replacement of a water pump in a C-6 Vette.
