engine won't start
Old Mar 8, 2014 | 02:43 PM
  #41
ftf396's Avatar
ftf396
Yes. With ignition in run engine will start. Checked + side of coil with test light and switch in run, no current. I assume testing it is to touch + terminal with one end and grounding the other tip to engine, right?
Old Mar 8, 2014 | 03:30 PM
  #42
Peterbuilt's Avatar
Peterbuilt
Are you saying that when you run a jumper from the top terminal of the solenoid to the small "S" terminal the starter spins the engine over. If yes that's good and tells you the solenoid and starter are good.
Does the starter turn the engine over when you turn the key to start?
Old Mar 8, 2014 | 03:45 PM
  #43
Patro46's Avatar
Patro46
OK. Here is what I would do. I would find the large red wire from under the steering column from the ignition switch and see if it had 12 volts with my test light while cranking. If it lights up while cranking then follow it to the next point, be it clutch safety, neutral safety, ect. If you DON'T get 12 volts from the big red wire leading from the ignition switch, then you either have a defective ignition switch or a key cylinder NOT engaging the ignition switch.
If you follow these instructions and don't find the problem your not following the instructions. If this happens, flip your underwear inside out and re-read this post...
Old Mar 8, 2014 | 04:44 PM
  #44
ftf396's Avatar
ftf396
Answer to the first question is yes it will spin. Second ques. Is no. Ignition switch will not start it.
Old Mar 8, 2014 | 05:18 PM
  #45
Peterbuilt's Avatar
Peterbuilt
Default See post 24
OK, you're getting very close to figuring this out.
The ignition switch is a little hard to get to.
See if you have 12 volts "TO" the neutral safety switch (with the key in start).
If not then follow Petro46 advise and see if you have power to and from the ignition switch.
If you have power into the nss push clutch pedal down and see if you have 12 volts on the other terminal of the nss. You can jumper both wires together but put the shifter in neutral first. If the car starts the nss is bad.
Still no start then find the break in the purple wire.
Old Mar 10, 2014 | 01:15 PM
  #46
ftf396's Avatar
ftf396
Just to let you know where I am at this point. Jumper end the clutch ness, did not crank. Tested both terminals in and out no power. In process of tracing purple wire for break as suggested. Patro46 said to check red wire from ignition switch, that's no so easy. Is that wire the same one that goes to wiper over ride. If so can voltage be checked there ?
Sorry to sound stupid with all the questions but in my first post I said electrical is not something I understand very well. Thanks
Old Mar 10, 2014 | 05:56 PM
  #47
Peterbuilt's Avatar
Peterbuilt
Thanks for the up date. Electrical problems are difficult to track down but when you find the problem it seems so easy to fix.
Power from the battery goes to the ignition switch then to the NNS (clutch switch in your case) and then to the "S" terminal on the starter. So if you have no power "TO" the nss then the problem can be in the ignition switch since that's the direction the power flows.
No point in checking the purple wire since it's downstream.
At this point you might contact a Corvette club in your area and get help.
Old Mar 10, 2014 | 10:32 PM
  #48
ftf396's Avatar
ftf396
Again thanks for all the replies from all, especially those who hung in there.
Sounds like the ign. switch. May have it replaced. If that doesn't solve it will take your advice. Thanks
Old Mar 11, 2014 | 01:25 AM
  #49
Patro46's Avatar
Patro46
Just food for thought. It's very seldom (though possible) the ignition switch simply goes "out". It's MORE likely the key cylinder isn't pushing the physical ignition switch far enough to make a good contact or another issue altogether. And yes, it's mighty tight under there, like everything else on these pretty little ladies. This said, IF I had ruled out everything else we've all talked about and HADN'T yet got the ignition switch accessible yet, here is what to do. Get a phillips head screwdriver and a 9/16" socket and extension. Remove the cover directly under the steering column. This will expose the two 9/16" nuts holding the column up. Remove these two nuts and you can carefully lower the column enough to expose the two 5/16" headed screws that secure the ignition switch to the column on the LEFT SIDE of the column. If you loosen them them up just a little, you can push the ignition switch toward the firewall a tad, then tighten. (It is designed to slide for proper adjustment). This will rule out the key cylinder rod not pushing the ignition switch far enough to make a good contact. ( This is a LOT easier and a lot less time consuming than you might think) Good luck!
Old Mar 11, 2014 | 10:26 AM
  #50
my 76 ray's Avatar
my 76 ray
And if that doesn't fix it you have most of the work to replace it done.
Old Mar 24, 2014 | 05:40 PM
  #51
69 Chevy's Avatar
69 Chevy
Hmmm, wonder what finally fixed it???
Old Mar 27, 2014 | 10:09 PM
  #52
ftf396's Avatar
ftf396
So far it's not. Work has kept me from doing much since last post,but what I have done is, checked clutch nss, it has power in but not at other terminal and motor won't crank when the wires are jumpered in the ignitions start position. I have checked power at the wiper override and have power at both terminals and has power all the time. it has red and red with white wires going to ignition switch. I have also adjusted the switch rod as suggested on left side of column with no results. When I do turn the switch to start the tcs terminal on the fire wall clicks not the starter. Still in a tizzy. But thanks for askin'.
Old Mar 27, 2014 | 11:34 PM
  #53
my 76 ray's Avatar
my 76 ray
If you have power at one of the two wires at the clutch switch when you turn the key to "start" and connecting the two wires at the clutch switch does not make it start when you turn the key, then it's likely a short in that wire that goes from the clutch switch to the small terminal on the engine side of the solenoid.
Old Mar 28, 2014 | 02:51 PM
  #54
ftf396's Avatar
ftf396
Thanks I will give that a try.
Old Apr 10, 2014 | 06:16 PM
  #55
ftf396's Avatar
ftf396
Well, finally got time to start tracing purple wire to starter but started at fire wall had to use invasive lighted volt tester, probed wire and grounded it, got in car to test and guess what, it started, go figure.
