1971 Corvette heater core
Old Feb 24, 2014 | 07:50 PM
Sundance LS5's Avatar
Sundance LS5
2nd Gear
Default 1971 Corvette heater core
I have a leaking heater core in my 1971 Corvette and it appears that I should be able change it from the engine side of the firewall. It would save time over the service manual's instructions to remove from inside passenger side. It's a BB non AC car. Anybody have experiences to share?
Old Feb 24, 2014 | 08:58 PM
Mooser's Avatar
Mooser
I'm really not sure if you can change the core from the engine side (but it would be nice, a lot easier to get at than from the dash) Non-AC might be possible
Several posters have given very detailed instructions on doing it here. Check with Paul74, I think he's done it both ways???
M
Old Feb 24, 2014 | 09:04 PM
Mashman's Avatar
Mashman
You need to remove the heater box, and its mounter to the firewall inside the cabin. Its not that difficult a job, but it does take some time.
*Edit* Sorry, missed the NON AC part, the above is only correct for AC cars.
Old Feb 24, 2014 | 11:37 PM
PeteZO6's Avatar
PeteZO6
I have never done the job from under the hood, by removing the the piece the heater motor mounts to, but I remember there are threads on the forum describing how to do it. Plenty of pictures too. If/when my heater core leaks, I plan to do it that way. No more removing the heater box inside the car for me.
Pete
Kim72's Avatar
Kim72
I've done it a couple of times over the years to my non-a/c 72. It's done from the engine compartment. Much easier than an a/c car. Suggestion: take your new heater core to a local rad shop and get them to check/redo the soldering. The quality of the new cores these days is not good. Antifreeze on the carpet is a bitch to get out. Tell me how I know!!
Old Feb 25, 2014 | 08:45 AM
Paul L's Avatar
Paul L
M
Yes, I did a couple (non-A/C) from the engine side. But they were not big block cars. In any case here you go:
http://www.corvettefaq.com/c3/heatercore.html
Old Feb 25, 2014 | 07:03 PM
Sundance LS5
2nd Gear
Thanks for the replies and advice. I will do it from the engine side of firewall and let you know how it goes.
To 1971 Corvette heater core
