Catalytic Converter Recommendation?
Old Jul 15, 2002 | 11:29 AM
terryrudy's Avatar
terryrudy
Default Catalytic Converter Recommendation?
Hi, I'm going to need to get a couple high-flow cats to throw on my exhaust real soon now and I'd like to order some today to take advantage of the Summit deal. Anyone have any recommendations? I have dual 2.5" exhaust and would like to go dual-cats (not EXACTLY legal, but close enough).
thanks!
-terry
Old Jul 15, 2002 | 11:33 AM
78RedShark's Avatar
78RedShark
Default Re: Catalytic Converter Recommendation? (terryrudy)
Suggestion - move to Ontario, Canada...no emissions testing for anything older than 1981. :D
Old Jul 15, 2002 | 11:46 AM
mountainmotor's Avatar
mountainmotor
The Cartech Brand is reported to flow with or out flow the expensive random Technologies Cat and cost a bit less,$59.95
CALL MUFFLER TECH TOLL FREE 1-877-722-3784.
Old Jul 15, 2002 | 11:49 AM
mrbeaubo's Avatar
mrbeaubo
Default Re: Catalytic Converter Recommendation? (mountainmotor)
What about the CatCo Converters on summit?
Old Jul 15, 2002 | 11:53 AM
Fevre's Avatar
Fevre
Now if I where you I would buy the converters put them on for testing and then take them off when I did some off roading with it. You have to decide what you def of 'off road' is. ;)
Old Jul 15, 2002 | 12:04 PM
Jman's Avatar
Jman
Default Re: Catalytic Converter Recommendation? (78RedShark)
Yeah, but then you have to put up with all those Canadians. Pretty soon he'll start talking like Terrance and Philip. :D :lol:
Old Jul 15, 2002 | 01:12 PM
Wrecked82's Avatar
Wrecked82
Car Sound
Old Jul 15, 2002 | 03:17 PM
Biker's Avatar
Biker
Default Re: Catalytic Converter Recommendation? (Larry82)
I use a high flow CatCo converter for emissions testing only. After the test I install a test pipe that I purchased off Ebay. Makes me wonder if Chevy had this in mind when they went with flanged joints at the catalytic.
Old Jul 15, 2002 | 04:00 PM
terryrudy's Avatar
terryrudy
Default Re: Catalytic Converter Recommendation? (Biker)
I think in the interest of saving time/money/possible exhaust leaks I'm going to leave the high flow cats in there. I think with the dual 2.5s, I got enough flow for my relatively mild motor. So hopefully dual cats won't rob me of too much. Thanks for the suggestions guys.
-terry
Old Jul 15, 2002 | 05:16 PM
Edzred72's Avatar
Edzred72
Just bought a set of these. They are less than half the size of stock, and when held up to sunlight... I can see right through em. All stainless body, with aluminum heat shield. Good Stuff!!!! :yesnod: :yesnod: :yesnod:
Eddie
Old Jul 15, 2002 | 06:21 PM
terryrudy's Avatar
terryrudy
Default Re: Catalytic Converter Recommendation? (Silvr77)
Eddie, sounds good!
Do you have a part # or any other specific info so I can just call and get the right ones?
thanks!
-terry
Old Jul 16, 2002 | 03:56 AM
Schmucker's Avatar
Schmucker
Move to Wisconsin, most counties have no emmissions testing. Period.
Old Jul 16, 2002 | 09:10 AM
Edzred72's Avatar
Edzred72
[Quote]The Cartech Brand is reported to flow with or out flow the expensive random Technologies Cat and cost a bit less,$59.95
CALL MUFFLER TECH TOLL FREE 1-877-722-3784.[Quote]
Mountainmotor said it all. Just call them toll free, explain what you have, and the guy will fix you up. I got mine in 5 working days, cause they are located in California and I'm in Illinois. Good Luck....
Eddie
Old Jul 16, 2002 | 12:18 PM
gmcclurg's Avatar
gmcclurg
OK, this will help get more exhaust out, but what are you doing to get more air in? I have a very stock 77 with the air pick up over the radiator. Are you just adding a K & W round filter to repalce the stock paper one or is anyone doing anything else? Am I better off removing the plastic pick up and just mounting an open filter on top of the carb?
Old Jul 16, 2002 | 03:23 PM
adam's Avatar
adam
Default Re: Catalytic Converter Recommendation? (gmcclurg)
Dynomax makes a dual in, dual out (2.5") I believe, maybe 3" too.
Would satisfy the requirement of 1 cat...
As good as true duals? Don't know.
Old Jul 16, 2002 | 03:50 PM
mountainmotor
Default Re: Catalytic Converter Recommendation? (adam)
I saw a test once of the Random cats.They were stuck right on the end of the collectors of a 600 HP Shotgun motor,,cost it 12 hp.Not really that much in my opinion especially with a 250-300 hp motor.Still need very good flowing mufflers though
Old Jul 16, 2002 | 05:51 PM
Ryan77's Avatar
Ryan77
To get more air in I used the K&N 14"x3" filter, Holley carb, and Edelbrock intake.= :D
To Catalytic Converter Recommendation?
