Dynomax header install. Question
Old Jul 15, 2002 | 12:25 PM
Stewart's74's Avatar
Stewart's74
Default Dynomax header install. Question
The passenger side header went in thru the top, took a total of 10 minutes to install. It appears that the driver side wont be as easy. I'm assuming its gonna have to be installed from the bottom. Who has done it and what should I look out for. It looks as though its gonna be a really tight squeeze with the steering gear.
Let me know boys and girls.
Stew
Old Jul 15, 2002 | 12:27 PM
Alwyn678's Avatar
Alwyn678
Default Re: Dynomax header install. Question (Stewart's74)
I went thru the bottom on the drivers side......Just take your time and it goes in just as easy :cheers:
Old Jul 15, 2002 | 12:41 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Yeap, I put my header on the drivers side in from the bottom. Just jack the car up about 1.5 feet and remove the spark plugs from the head. If you have a manual you will have to pull the Z-bar. Other than that it just pops right in.
Mark B.
Old Jul 15, 2002 | 01:18 PM
Pedro'74's Avatar
Pedro'74
Default Re: Dynomax header install. Question (Sigforty)
Yep, from the bottom. It helps if you remove the spark plugs and the oil pressure sender.
-Pedro
Old Jul 15, 2002 | 02:50 PM
Stewart's74
Yep, you guys were right on the money. I just got done putting it on. I did have to remove the oil dipstick tube as well. These things look freekin awesome!
To Dynomax header install. Question
