What mods are required to install the Richmond 5 speed in place of a original super t10?
The richmond, th200R4, and th700R4 have the same tail shaft mounting point. so if you are not a fabricator or welder it is as simple as purchasing a bowtie overdrives or a G-force cross member.
With 3.70 gears, you will definitely be looking for an overdrive!!! Unless you intend to cruise on the two lane back roads all the time! I put 3.55 in a 4 speed camaro. Cruising on the interstate in the slow lane sucks after the first 5 minutes and cranking it up to cruise in the fast lane sucks even worse without an overdrive! IMHO
Doing it yourself all depends on your mechanical competency. There are good videos on the web on how to do it. If you have any doubt about your ability, don't do it. They are not that difficult to do, but require a few special tools, time, and patients. You want to aim for perfection, not just good enough.
I built a Super 10 with Richmond 4.11 gears last summer. It required much more time and some machine work for the 12 bolt size cross pin and larger stub axles. I have built differentials since I was a teen (a long time ago), but this one was a springless posi, a first for me. I watched and read everything Gary and Tom (Tom's Differentials) had on the web. Even old dogs need to learn new tricks sometimes. I have a machine shop too. You would have to outsource the machine work if you don't have a mill and lathe.
Gary and Mike mentioned in a previous post have excellent reputations and one of them would be who I would send mine to if I couldn't do it myself. Whoever you send it to, tell them your power level and if you plan on upping the power later so they know how beefy the diff should be built.
And yes, you will definitely feel the difference in gearing.
hmmm I didn't realize changing the trans might give me the same end result... I just wanna be able to realllllllly smoke the tires off the line... I never drive on the hiway.. maybe a few times a year and I have sidepipes so its loud anyways...
Since hi way driving is not an issue, there is no downside to changing rear gears. Have the 3.70s put in for half the cost of a trans, or less. Use the money you save for tires.
Changing to the Richmond trans actually gives you much better results. 5th gear would be like you have now. 1st through 4th would be like you have now if you changed to 4.56 gears.
If you have 308 flywheel HP now.
The trans change makes first gear feel like 456 hp.
The differential change will make it feel like 370 hp.
I would like to go the other way with my gear ratio. When I bought my 1969 427 390 hp the owner said that the rear ratio was changed to 4.11. I would like to return my car to the original ratio. I was thinking 3.36? Not really sure. The owner gave me a set of gears and a posi unit. I have no idea what ratio they are or if any of it is worth keeping.
Its easy to figure out. Count the number of teeth on each gear and divide and You will have the ratio. The Gears probably have a manufacturer Stamp on them and also probably have the gear tooth count stamped on them as well. Depending on what manufacturer they are should tell you if they are OEM. Another option is to look at the Codes Stamped on the bottom of the Pumpkin and it will tell You what it left the factory with, providing its the original to the car. The date code would be a good clue if its the original for the car. The build sheet would tell the story of what was installed on the assembly line.
My 68 with a stock Muncie and a 3.73:1 would spin about 3000 rpm at 60 mph ....just really hated the engine speed at such low freeway speeds...the engine was just wearing itself out.
I installed a TKO 600 5 speed overdrive tranny...now I turn 2000 rpm at 70 mph and have a tremendous first gear. Can light up the wheels in first gear and still cruise with a very economical, quiet, engine non-wearing speed.
If you have a 3.08:1 diff, you need to buy a Richmond 5 speed. They have a 1:1 in fifth gear, with a sort of bull dog 1st gear. The TKO won't work with a 3.08:1 diff.
