Not if the car is wired correctly. The solenoid sends a full-voltage signal to the coil when the ignition switch is in the "START" position. Once the engine starts and the ignition switch is returned to the "RUN" position, coil voltage is disconnected from the solenoid and is then fed through a resistance wire coming from the fuse block.
After the engine starts, the solenoid SHOULD have no effect on the engine or its ability to run. Again, this is assuming that the wiring is run as the factory intended.
About a month ago and about 6 months ago my car stopped dead in its tracks, turned the key nothing, not even a click from the solenoid
Next day it was fine
This past weekend i tried to start the car
started engaged, engine cranked fast then nothing,
(the car has to crank a lot when it sits a few days when cold)
I am going to jump test the solenoid this Saturday by connecting power to the purple wire (I am assuming a bad solenoid at this point cause I have to crank the car so much) but wondered if the two issues were related
The no click when starting and the sudden loss of ignition
as mentioned , check the ground at the frame under the car. also next time it wont start try it with the shifter in neutral, could be neutral safety switch on the shifter giving you trouble if its an automatic.
Wiring goes bad, too. You can't see inside the insulation on battery cables. But, they could have turned to powder in there. And, just checking them with an ohmmeter doesn't get it. You need to know that the cables can pass adequate CURRENT...not just battery voltage.
Also, verify that you have a good ground cable (right side A-arm area to enging block/starter bracket). If that is bad...or missing...it will cause the same problem.
I had a problem like this once, had to take the solenoid apart and clean the contacts inside of it. AND while you have the starter apart, it always good to change the brushes and clean the starter up. Paint it and you are good for another 50, 000 miles!
check all wiring while taking the starter apart, make sure the black round wire is not put on the starter solenoid.
I think everything, the radio had lost all it's memorized stations
Sounds like the main wiring then. Check and clean;
the battery terminals
the other end of the negative wire at the frame
the short jumper between the frame and engine block both ends
the positive cable at the starter solenoid
Once you get to solenoid also check the fusible links connected to the solenoid since those power everything else.
While checking connections the positive and negative cables were not real tight. It looks like arching occurred so I will clean the connections with a brush and put it back together.
