Rough start, low idle, missfire?
Old Feb 27, 2014 | 05:35 PM
Fragsrus's Avatar
Fragsrus
2nd Gear
Default Rough start, low idle, missfire?
So, we just bought a 76 with the L-82 engine last week. It ran fine when we bought it, and up until yesterday. It has been steadily harder to start in the cold mornings, and then yesterday afternoon it started to idle really rough and really low ~500 when in gear and ~750 when in neutral. Yesterday evening on the way home, it seemed like maybe a cylinder was not firing? I am not exactly sure if that's what is happening or not, but the engine was running really rough, like there was a gap in the cycle somewhere, and there was an obvious lack of power when stepping on the gas. Does this sound like a simple ignition system issue or is there something else that could cause all this? I have never owned a car this old before, never owned any carburated, so I apologize for what I am sure is a completely amature question. Thanks in advance for any help I can get.
Old Feb 27, 2014 | 05:44 PM
MrJlr's Avatar
MrJlr
New car to you - start with a good tune up and change the fuel filter (and air filter.)......God knows how long it's been.
Cap, rotor, plugs and wires.
Make sure you are getting spark and fuel.
Old Mar 22, 2014 | 10:50 PM
Fragsrus's Avatar
Fragsrus
2nd Gear
SO, it turns out I just didn't notice that one of the spark plug wires had been resting on the header, had burned it's way down to the bare wires, causing it to loose spark. My new question is, there is a sucking sound when starting and it takes a good 4-5 attempts to finally get it to start. Even then, when it does start, it takes another 4-5 mins before it can be put into gear without it stalling out. Is this just common of these old engine? Or is there something I can fix to remedy this?
To Rough start, low idle, missfire?
