exhaust system question please 4sp vrs auto
I got some new 350 auto dual exhaust pipes (Corvette Central) from a friend and I want to put them on a 76 4sp to convert to dual exhaust.
Does the removable cross member on the auto have the same 2 exhaust holes dimensions as the 4sp welded in cross member?
Are the front pipes different for the auto and 4sp? I assume the auto front pipes may split wider to accommodate the larger auto transmission.
So the question is: will a 350 auto dual exhaust fit on a 350 4sp dual exhaust without modification???
Thanks!
Thanks!
The auto pipes, I think pass side, I believe enter the crossmember hole at a slight angle, making both the front and rear pipes slightly different from the manual pipes that go through straight. You won't be able to connect a manual front pipe with an auto rear pipe. Or vise-verse.
Few years ago I installed a manual setup I removed from one of my Vettes onto a friends auto Vette. Had to ding a few spots to clear the turbo 350. No way they would have worked with the 400 trans.
In your case, with the small size of the manual trans, I would think the auto pipes would fit OK.
I'm assuming a COMPLETE auto set is what you're getting.
If you're using a "correct" factory style hanger.
Studied the intermediate pipes and sure enough, there is an angled female connection just ahead of transmission support on the passenger side. The 4 sp front feeds straight in as you said.
Driver side looks straight and likely will work. I think on the passenger side, I can cut the intermediate pipe back beyond the angle and splice in a straight piece.
So, there are options as always
! (Bubba is our friend! what would we do without BUBBA???
)Thanks for all of the info and help!
