Holley Fuel Leak
Old Mar 2, 2014 | 03:25 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
Default Holley Fuel Leak
I have fuel weeping out of the screw that I am pointing to with the screwdriver. I read the service manual, and this adjusts the fuel level in the bowl using the side sight plug. Seems like if fuel is leaking, the bowl is filling past the sight pushing it out the top. This would tell me to adjust it per the manual to lower the level.
Is there something different happening here that I need to be aware of? Of is it simply lowering the fuel level like I said above.
Old Mar 2, 2014 | 03:58 PM
lars's Avatar
lars
That is the float adjustment screw, but leaking fuel at that point has nothing to do with the float level being high. If fuel is leaking there, it's because the 2 gaskets have been installed dry, and have shredded/broken when the float was adjusted.
To fix, remove the slotted screw and removed the hex nut. Replace both of the gaskets with new gaskets. Put some assembly lube on both sides of both gaskets before you install them. Once installed, set the float level with the engine running to the lower edge of the sight hole on the passenger side of the bowl and then snug down the slotted screw. It will not leak with new gaskets with lube applied.
Lars
Old Mar 2, 2014 | 04:01 PM
Patro46's Avatar
Patro46
Yes. Before you start adjusting the float, pull (unscrew) the float level inspection screw. Full should NOT flow out of here. If you can rock the fender and make it spill out the hole its about right. Also note there are 2 (two) gaskets under the float adjustment screw that are prone to tearing when adjusting. These can be bought at about any auto parts store. Or you can make then from gasket material.
Old Mar 2, 2014 | 04:03 PM
74modified's Avatar
74modified
[QUOTE=Dan H.;1586302641]I have fuel weeping out of the screw that I am pointing to with the screwdriver. I read the service manual, and this adjusts the fuel level in the bowl using the side sight plug. Seems like if fuel is leaking, the bowl is filling past the sight pushing it out the top. This would tell me to adjust it per the manual to lower the level.
Well the adjuster is right over the needle/seat and uses small gaskets to prevent fuel weeping. You should adjust the float level to the correct position. Do this wet (sight hole) or dry (measure the float by opening the bowl). But, don't just start turning things, unless they need it, it could just be a gasket. Since you are pointing at the rear bowl, you have to crack the rear throttle to pull down the fuel level after an adjustment.
Old Mar 2, 2014 | 04:35 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
Thank you guys
A dried/cracked gasket could likely be the issue. I will pull the crew and check the gaskets. This car has done far more sitting than driving. Carb was off for a year while I was taking care of other items. Since I put it all back together, I've only driven it about 20 miles. And since then, its been hibernating during this northeast winter....
Old Mar 2, 2014 | 05:29 PM
scottyp99's Avatar
scottyp99
Probably be a good idea to rebuild it.
Scott
Old Mar 2, 2014 | 05:47 PM
gluvnaa's Avatar
gluvnaa
Q: What is that wire running beside your valve cover and your intake?
Old Mar 2, 2014 | 06:43 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
Good Question. Honestly, I'm not sure. It plugs into that solenoid you can see on the carb, on the bottom left. I'm learning as I go so I feel a little dumb not being able to answer. Car is an LT-1, not sure if that makes a difference or not.
Old Mar 2, 2014 | 07:32 PM
lars's Avatar
lars
It's the wire for the idle-up solenoid. It prevents run-on after shutdown if the solenoid, along with the carb's curb idle, is all set up and adjusted correctly.
Lars
To Holley Fuel Leak
