L48 upgrade why not???
Scott
Cheap pays twice
do it right the first time and you wont be doing all over again later...
the other truth:
cheap, reliable, fast..... you can only choose 2. right now you picked cheap and reliable.. but dog slow.
http://www.summitracing.com/parts/na...0283/overview/
This
http://www.summitracing.com/parts/na...2586/overview/
and these;
http://www.summitracing.com/parts/nal-12499224
You will have to buy 787 retainers from comp to fit the springs, a vortec intake, gaskets and electric fuel pump and regulator but it should get you 400 HP for well under $3000. 99% new GM, No warrantee.
http://www.thirdgen.org/techboard/te...am-vortec.html
my only issue with this is years ago I did this to a 350 and basically blew out the rings with in a year and started burning oil like crazy.
My current engine was rebuilt 35k miles ago bored 30 over. I would be afraid of doing the same thing.
I have no Idea of the quality of parts or workmanship.
I do have the receipt from the previous owner but it doesn't list in detail what parts were used.
This is why I'm leaning towards a crate engine. Otherwise I have a feeling I'm going to end up putting 5k into my current engine. But i am guessing at best.
So after reading this I guess im saying my budget including labor to install the engine is 5k or less.
http://www.blueprintengines.com/inde...1-engine-specs
Here's the link to my swap
http://forums.corvetteforum.com/c3-t...int-383-a.html
So far so goo and this engine is VERY strong...
No tearing apart and voiding the warranty, no machining, no re-assembly...just pull old and replace
If not that engine, something similar. I just think it's a great price.
I would ask that blueprint company what a 350 set up like the 383 would cost ya. Should be cheaper.
They have a 355CID that is quite a little beast too....another forum member has it and is VERY happy with it...
http://www.blueprintengines.com/inde...ase-bp35513ct1
$3395
From the link:
HP & Torque: 390 HP / 410 FT LBS
Compression Ratio: 10.1:1
Aluminum Heads
Hypereutectic Pistons
Roller Cam
Cast Steel Crank
Part #: BP35513CT1
Block:
4-bolt main, 1-piece rear main seal
Passenger side dipstick
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
BluePrint premium cast steel crankshaft
Hypereutectic pistons
Chevy heavy beam rods with 150,000 PSI bolts
Hastings moly rings
Melling high volume oil pump
Hydraulic roller cam
Heavy duty double roller timing set
Cylinder Heads:
BluePrint Performance aluminium
Hardened retainers and springs
2.02 swirl polished intake valves
1.60 swirl polished exhaust valves
BP Aluminum Head Part# H8002K
For complete head specs, click here
Cam Specs:
Cam Type: Roller
.495 Intake .503 Exhaust
220 Intake / 224 Exhaust duration
@ .050 - 112 degree lobe separation
Ignition Timing:
34 degrees at 4000 RPM
Also Includes:
New valve covers
Oil pan
Timing cover
Brass freeze plugs
Dyno test results shipped with engine
Notes:
This engine is very similar to our BP35512CT1, but this engine offers a roller cam. If you have questions on the benefits of a roller cam vs a flat tappet cam, please feel free to contact us!
How are you liking you engine? any issues? I'm getting close to pulling the trigger on one of those blueprint engines. From what I can tell i think it's going to fit my needs and budget fairly well. So far my biggest problem is i keep looking at them and going well for another $300 i can get this .. next thing i know im looking at the $4500 engine. lol
That Blueprint 383 sound like it would fit the bill. Good luck with the engine change.
Don't spend money on conveniences. You'll be spending your time and effort instead. Don't spend money on shiny things. The stock valave covers work just fine. Roller tipped rockers are a waste of money. They don't eliminate enough friction to make them worth it. (roller trunions are a different story) Shop around for good deals. Things like that.Scott
Between machine work and rotating assembly you will only be into it for @$1500 add a set of aluminum heads and you'll have a great street burner for @$2500
Or the dirt cheap way to go since you only have 30k for mileage. Pick up a re-ring kit with bearing. Pick up some small chamber heads to bump up compression and match a cam to it! You'll have 300 hp for $1500. Building up a running motor take a lot of risk out of the build and you'll see if anything was compromised over the years on tear down.
http://paceperformance.com/i-5146074...ck-engine.html
When I looked into replacing the camshaft, heads and intake it was going to run at least $2k paying someone to do it.
Tell me why shouldn't buy this 260hp from jegs for 1,500 (free shipping too) change out the cam put factory intake on it and call it good with maybe 275- 280 hp and have a brand new engine from top to bottom?
Is this a decent idea or am I way off base here.
specs for engine
Chevrolet Performance 10067353 GM Goodwrench 350ci Engine
260HP/350TQ
4-Bolt Main
3-Year/100,000 Mile Warranty
never mind now that i check the website is saying it's not compatible with a 73 vette
