Tilt-Telly Steering Column
Old Mar 5, 2014 | 07:29 PM
gsimon767's Avatar
gsimon767
Default Tilt-Telly Steering Column
The steering column pictured shows a small 4-5 inch rod next to the column. I believe it is called a tele lock rod. I was moving the column with the steering wheel end pointing down. The rod fell out and I can't figure out where it goes. Can anyone help me put this rod back?
Old Mar 5, 2014 | 10:42 PM
noonie's Avatar
noonie
Hole in the center of the shaft steering wheel end under the phillips headed star bolt.
Old Mar 6, 2014 | 12:07 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It goes inside the upper shaft, the star bolt push's it to lock the column.
To Tilt-Telly Steering Column
