Header Wraps
Old Mar 4, 2014 | 08:04 PM
ctuinstra's Avatar
ctuinstra
Default Header Wraps
What are your thoughts. Over the years I've heard many opinion on them. I'm thinking about getting a set of headers and wrapping them to help cut down on some of the heat and the ugly rusted header look. It's that or ceramic coated.
What say ye?
Old Mar 4, 2014 | 08:06 PM
TimAT's Avatar
TimAT
Just a $.02 opinion- if the wrap gets wet, it stays wet and can accelerate the rusting. Ceramic coating won't rust. I've also seen that some header manufacturers won't warranty wrapped headers too.
Old Mar 4, 2014 | 08:17 PM
ctuinstra's Avatar
ctuinstra
That's one of the big arguments that I have heard about wraps. While the proponents say all you have to do is run the engine for a few minutes to dry them out. It's not a major concern of mine because the car will never see rain if I have anything to do with it; only a garden hose on a Saturday afternoon.
Old Mar 4, 2014 | 08:31 PM
Roco71's Avatar
Roco71
Google it and read the advantages and disadvantages. I would go with ceramic if its in the budget.
Old Mar 4, 2014 | 09:31 PM
CWerner's Avatar
CWerner
What is the real advantage of coated headers vs stainless steel? I know the obvious is temp, but how much?
Old Mar 4, 2014 | 09:47 PM
Duane4238's Avatar
Duane4238
Different twist on wrap. Don't have headers but want to wrap the pipes that run under passenger compartment. My pipes are stainless. Will this cause any problems?
Duane
Old Mar 4, 2014 | 11:35 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
The stuff is U-G-L-Y.......BUT......I've had wrap from the collectors down under the floorboard on my '34 SBC truck for 7 years. I unwrapped the ends a year ago to check for damage because of negative comment concerning wrap---NO RUST!
*****BUT IT'S A DAILY DRIVER!******
The wrap never stays wet for days/weeks/months at a time.
I'll bead-blast the headers/coat with hi-temp paint/wrap them also.
(Go ahead.....I put my flak-jacket on )
Old Mar 5, 2014 | 12:38 PM
REELAV8R's Avatar
REELAV8R
The Jet Hot ceramic coating is very durable and is permanent. Won't rust and still looks good. Worth the money to me. JMO
Old Mar 5, 2014 | 03:29 PM
keithinspace's Avatar
keithinspace
My engine builder is very much AGAINST wrapping headers. He has seen the results of the heat that is stored behind them and the resulting cracking and things...especially at the 'bends' of header pipes.
The moisture issue along the sidepipes would be an issue as well.
Old Mar 5, 2014 | 04:05 PM
ddawson's Avatar
ddawson
Coated also means the inside and outside of the tubes are coated.
I've seen 1st hand with with stainless steels headers un-wrapped that they still seem to breakdown the metal.
Found this with a google search.
Old Mar 5, 2014 | 05:42 PM
SB64's Avatar
SB64
Default headers
Can you powder coat headers like we do for the frame???
Old Mar 5, 2014 | 06:41 PM
M-yellow01's Avatar
M-yellow01
My 2cents. I wrapped headers on a 78, mainly to cut down on the heat in the cockpit. It did help a bit, but now I have a 75 with stainless unwrapped headers. But....this car has dyno-mat under the carpet. Thats the real answer to heat seeping through the floor boards. I had the 78 for about 8 yrs with the wraps. I used worm gear claps on the ends and painted them heat tolerent silver. Never had a problem, whatsoever. I kinda dug the wrapped headers, looked like a 60s throw back.
Old Mar 5, 2014 | 06:56 PM
DUB's Avatar
DUB
NO...the heat coating is a specific coating that is applied. Powder coating...or at least I have never heard of it being used due to the whole issue is trying to provide radiant heat protection which I do not think powder coating has that ability.
DUB
Old Mar 5, 2014 | 07:54 PM
SB64's Avatar
SB64
DUB
Thanks Dub for answering my dumb question
Old Mar 5, 2014 | 07:56 PM
Scottd's Avatar
Scottd
You will have to remove your headers to wrap them correctly. Its impossible to cover them completely if they are still installed. So if you are going to remove them, just go ahead and replace them with a set of ceramic coated headers. The look much better and have some heat retention capabilities. Go ceramic coated and you will never regret it. Header wraps are great on race cars where scavenging heat is necessary to pull exhaust at high RPMS, but they just arent all that effective on a daily driver.
Old Mar 5, 2014 | 08:03 PM
ctuinstra's Avatar
ctuinstra
I've never been fully convinced of the advantages of wrapping versus the issues. I don't think I'll mess with it. Ceramic is the way that I'm going to go.
Old Mar 6, 2014 | 07:13 AM
gsixl's Avatar
gsixl
I wrap my headers as it cuts the heat under the hood tremendously. I also think if done correctly they look great and have little effect on longevity of header. I have had them wrapped on my daily driver for years with no problems. I use DEI silicone header paint and the more the better. First paint your headers and let them dry. The wrap should be cut a little longer then you will need for the tube you are wrapping. Soaking the wrap in water then zip tie your start end. The wrap will stretch nicely when wet and try to keep a 1/4 inch overlap. When finished zip tie the other end. Do all tubes with the last wrap doing the collector. I then let the wrap dry and then put on the stainless bands. After all this saturate the wrap with the DEI silicone paint. The more the better I use a couple of cans on a pair of headers. This will seal the wrap and keep them looking great. I think where people get the burned out headers is from incorrect fuel mixture causing high header heat.
To Header Wraps
