Removing dowel pins quick help please!
Old Mar 8, 2014 | 10:51 AM
Crahm's Avatar
Crahm
Default Removing dowel pins quick help please!
I'm trying to remove the dowel pins for the bell housing for my 427.
Engine is in car.
Can I not drive the dowel pins foward to the front of the car rather than towards the rear?
No room to swing a hammer on the front side.
Old Mar 8, 2014 | 12:23 PM
7T1vette's Avatar
7T1vette
Nope. Why do you want them out?
Old Mar 8, 2014 | 01:50 PM
Shark Racer's Avatar
Shark Racer
Likely to zero a bellhousing...
http://forums.corvetteforum.com/1586349159-post23.html
Old Mar 8, 2014 | 04:31 PM
Robert Thomas's Avatar
Robert Thomas
Army Hoist Operator
Taking appropriate safety precautions, tightly clamp vise grips on the pin with enough space to get a big flat blade screw driver blade between the pliers and the bell housing. Pry up on the pliers with the screw driver. Push the screwdriver handle down, don't pull up.
Old Mar 8, 2014 | 08:59 PM
Shark Racer
Mine were effing tight in the block - we ended up using a jack screw method to get them out. Drilled and tapped the dowels and pushed them out w/ a large socket...
To Removing dowel pins quick help please!
