Long water pump and frame clearance
Old Mar 9, 2014 | 10:04 AM
SteveCurry's Avatar
SteveCurry
Default Long water pump and frame clearance
I was at the Good Guys show yesterday and talked to the guy in the March Performance booth. I told him I was interested in brackets and pulleys for a Gen II PS pump and an alternator. I told him I bought a Weiand long pump and needed brackets and pulleys for that pump.
He told me you can't use a long pump in a C3 or the crank pulley will hit the cross member. I don't know, the engine is out of the car and this is my first Chevy. What's the real story on that?
Thanks!
Old Mar 9, 2014 | 10:51 AM
Mike Ward's Avatar
Mike Ward
The guy was right. End of story.
Old Mar 9, 2014 | 12:12 PM
SteveCurry's Avatar
SteveCurry
OK, guess I'll have to notch the cross member.
Old Mar 9, 2014 | 12:21 PM
Mike Ward's Avatar
Mike Ward
Bad idea. Get the correct water pump.
Old Mar 9, 2014 | 05:34 PM
SteveCurry's Avatar
SteveCurry
Can't use the short pump. The brackets I want to use require the long pump. I'm moving a 100 Amp alternator to the right side and am going to use a new Gen II PS pump like the LS motors use for the Steeroid rack and pinion. The brackets for both require the long pump.
Old Mar 9, 2014 | 05:48 PM
diehrd's Avatar
diehrd
Why would you prefer to cut the frame over using the right parts ?
Old Mar 9, 2014 | 06:15 PM
tixeon's Avatar
tixeon
Some how I got away with using a long pump in my 80 with out notching frame. I converted to a stock F body serpentine belt drive and every thing fit under the hood but the hard AC line coming off the compressor. I will have to find a different line setup.I am using electric fans so I don't have the stock shroud.
Old Mar 9, 2014 | 06:32 PM
SteveCurry's Avatar
SteveCurry
What would you consider as the right parts? I don't have any interest in keeping the car original, my goal is to make it a better driving car and more enjoyable to use.
Old Mar 9, 2014 | 06:34 PM
SteveCurry's Avatar
SteveCurry
I'm not using the stock shroud or fan either. I wonder if using a smaller under drive crank pulley would make a difference?
Old Mar 9, 2014 | 06:49 PM
Kacyc3's Avatar
Kacyc3
I used a serp set up from an 87 camaro with the stock crank pulley and a new long/camaro water pump and have no issues. also not using the stock shroud or mech fan.
Old Mar 9, 2014 | 07:44 PM
SteveCurry's Avatar
SteveCurry
Do you know the diameter of the crank pulley you're using? The stock crank pulley that came with my car is 7 5/16" in diameter. The crank pulley I'm looking at is 6.6" in diameter.
Old Mar 9, 2014 | 08:58 PM
Kacyc3's Avatar
Kacyc3
from what i can see it looks like 7 3/4"
Old Mar 9, 2014 | 09:36 PM
SteveCurry's Avatar
SteveCurry
Thanks for checking! Ok, your serpentine crank pulley is larger in diameter than my factory pulley. Interesting.
To Long water pump and frame clearance
